2021 1500 5.7 etorque
Joemac
My 2021 1500 eTorque has a constant rumbling coming From rear driver side seat area. IT IS CONSTANT BETWEEN 25 TO 55 mph.
Not as noticeable on interstate speeds. Dealer says" normal for eTorque". Does anyone else experience this and is there a fix?
I am ready to trade for a new Tundra like the one I traded in. Never had 1 problem with it!
UnloosedChewtoy
5thGenRams Supporter
South Dakota
Either take it to a different dealer, or take one of their new 2021 models out for a drive with the service manager or the tech, and then take them for a short drive in yours. Show him how the one on their lot doesn't do that, and yours does. Sometimes its easier to demonstrate to someone the difference if you do it back-to-back.
U
User_3336
Guest
Is the "rumble" causing a driveability issue? that would seriously make you trade for a Tundra?
Did you not notice this "rumble" during your test drive?
NOTE! The Etorque battery is behind the back seat. Its fan cooled, so is this the noise you are hearing?
Bt10
MI
Might it be the eco mode? Mine rumbles in eco, and it is a common complaint with aftermarket exhausts.
Tinshield
This. I'd pay attention to see if the vibration is active with MDS is on. I think it is a normal sensation and it's subtle but there.
Louhound88
No noise from my etorque. I have a borla s type now and mds sounds different but still quiet.
Is it constant between those speeds regardless of rpm? If it were etorque motor winding issues I'd suspect to hear it vary with rpm. If it's constant between just tire speed then it may be suspension or wheel related.
fishslayer
Whiskey Bay LA
Whatever it is, it is not normal.. unless its the exhaust sound changing when MDS goes into 4 cyl ECO mode .. SEE YOUR DEALER
