I have been scouring the net to find details on replacing the factory inverter and can't find any good answers.
Of course I could install an extra inverter: connect it to the battery and ground to chasis, mount it somewhere like maybe under rear seat of cab or bed, place an online fuse on the power from the battery, add a remote/toggle to power on and off, use proper Guage wire, make sure the inverter doesn'texceed my alternator, only use while truck is running...etc... but in doing all that, I basically just took the easy route and abandoned the outlets I already have.
What I would prefer to do is REPLACE the factory inverter located under my passenger seat with a bigger inverter and make the outlets I already have, usable! The questions that come to mind=
Can the existing wiring handle a bigger inverter?
Where are the 150w breakers?- at the outlets? -inline between outlets and inverter somewhere? Built into oem inverter ?
Has anyone successfully "upgraded/replaced" the factory inverter and gotten more watage from the built in outlets?
Thanks for any help!
