Rookie2332
- Sep 30, 2019
I really like how that turned out. The red looks great with the Night Edition package. It's unusual to find a Night Edition with the ORP. That's what I've ordered.2020 larimie with off road package.
Achieved lift with moto fab 2.5 front and 1.5 in back. Tires 35x12.5x20 with fuel contra 20x9. -2 offset. Tires just inside fenderwells with the molding.
View attachment 42391 View attachment 42393 View attachment 42392
How's the rubbing with those tires?
What rear spacer did you use? And what did you do about shocks? I want to boost my Night Edition Laramie with the ORP. Mines in Granite Crystal. I’m having a hard time coming up with answers for a 3.5” lift.Also forgot to mention on lift was a tough country upper control arm used to keep angles inline.
Thank you sir. I may do the Readylift front level with control arms and the motofab rear spacer. I was worried with 1.5” in the rear it would put it too far off being level, but 1/2” is perfect in my opinion.Moto fab spacers
2.5 in front since already had 1" lift with spring/shock package
1.5" rear. This brings truck within a 1/2" of level
In the instructions for front spacers it does remind you that orp package that struts will need to go to a press. Spring needs to be rotated 180° as the tower angles the unit.
Also went with tough country upper control arm. With lift it's a must have to keep angles in place.
Also as mentioned little plastic trimming was needed to avoid rubbing on full turn with size of tire/wheel offset I went with.
Didn’t do anything with the shocks, in terms of lengthening?
