2020 got a makeover
aimlowrobin
6 inch BDS lift, 10" fuel vapaor wheels with -18 offset, MT Baja atz p3 tires in 35x12.5. Window tint, bull bar with lights up next.
justinbeez
Did the shop specify the minor changes in the braces? Say if someone wanted to go 4" I believe they're the same for the 4 and 6" lifts.
aimlowrobin
They said the crossmember mounting holes were slightly different but not enough to need any modifications.
aimlowrobin
Congrats. Looks awesome? How's the ride quality?
Thanks! Honestly, the ride is comparable to stock. I am so glad I spent the money on the BDS. My shop really pushed me hard to wait for BDS to be available. I test drove a 2020 with a RC lift, and it rode significantly rougher than stock.
aimlowrobin
For anyone interested, this combo ended up with only a very slight rub at full left turn moving fwd with level change. eg - pulling into my driveway, a bit of a bump. The contact is the very bottom of the stock mudflap.
justinbeez
Do you known if the bolts were then put in at an angle? I would see that being a problem trying to go off road with a torqued bolt at an angle and BDS not covering you because you bought a 2019 kit and slapped it on a 2020. I really want the 4" but my lack of patience in addition to BDS always dragging their feet makes me want to just go for bilsteins.
