2020 ecodiesel cold weather grille cover
JoeEcodiesel
Lake Hopatcong
First time Ram owner, picked up my new ecodiesel today and was curious about the cold weather grille cover. I know the truck has active flaps but I wanted to know if I still need to get a cover.
Thanks!
Sent from my Pixel 4 XL using Tapatalk
Also what's the deal with the engine block heater? Thanks!
Depends on where you are for cover but it does help quite a bit, I would recommend putting it on. Did your truck come equipped with block heater?? If it did I would certainly use it for certain temperatures.
Thanks!
Congrats on your new rig. Please include your truck's vitals on your signature, so folks can help with future questions.
Cheers,
I can't find where to buy a cover? My truck, as far as I know, doesn't have the block heater. I thought I seen somewhere all of the ecodiesels have it and you just need to buy the cord...idk
2020 Laramie Ecodiesel, Crew cab, 4x4, Level 2, Night Edition
Your dealer should be able to get you the cover, did you order the cold weather group, as for block heater I am not sure, your equipment listing should show it if it is installed.
I found the part number for the cover 82216061AA and lists for $125. If you have sales code MFQ. MF5 on your equipment listing then it should have been included.
Wow, thank you for digging into this for me! I appreciate it
