2020 Big Ram Not cranking
sergiorgalicia
Have an issue with my truck not cranking. I got stuck in a pile of snow saturday night and sunday morning when i went to start it it did not want to go. The battery is holding between 11-14v checked with meter but haven’t used a battery tester yet. I think it could be the starter since it clicks but never tried to crank and all electronics work fine. Any thoughts ?
I'm having a similar issue right now with mine I have the same truck I have an appt with ram on Monday if you don't figure it out by then I'll let you know the outcome
my issue ended up being that the Body and Cab Control Systems - RADIO FREQUENCY HUB shorted out and went bad from a leak cause by a faulty seal on the rear window and third tail light. the short causes the RF hub to power up which in turn will turn on all sorts of different accessories randomly and will drain your battery below the require threshold to start. I ended up needed to have the back glass and seal replaced along with the sela on the third tail light, then get a new RF Hub installed and wired and programmed. I do recommend taking it to a dealer mechanic and getting OEM parts for this repair.
