2019 With HK system - Adding mono amp and subs
Chavez98
Hello All,
Requesting some help on modules I need for an amp install. I did some searching but finding straight answers has been difficult. I have a 19 Ram with the HK sound system and ANC. I would like to add a mono amp to power some subs. I read PAC ANC-CH01 can be used to bypass ANC and be used to get signal for the amp. Does this sound correct? Would I simply add a line converter to the PAC ANC-CH01? Or cut some RCAs and tie into the PAC module?
Thanks in advance.
fossy007
All you need is the AP4-CH41 and no LOC. It outputs a full range signal. That's all I added to my HK system for adding a sub.
Chavez98
By any chance did your screen go blank after install? I have everything connected. Amp works, control sound from the stereo button but my screen is blank.
