2019 Speaker Static Issue
Droff
I've got a 2019 RAM1500 and for the first time today, the speakers developed a lot of static, no matter what input is selected. My wife drove it for roughly 45 minutes today before this happened and it hasn't corrected itself. I've looked over a few forums and have seen where folks have had a similar issue but no real resolution. A post mentioned a TSB but that appears to be only for 2021 and newer models. I've currently disconnected the battery and will reconnect to see if anything has reset. That's not much of a fix but hopefully will help with the issue at least as a temp fix.
Any other folks have this issue with a good resolution?
Thanks.
rconiv
Thanks.
All I can give you is I have this issue, but it doesn't seem to be with the radio, just my new iPhone 14se, though that could just be a quincidence since I just got it around the time you mention. It seems to be more prevalent with music that has heavier base. I think it showed up after I installed the firmware update I found here to fix the wireless connecting but not getting an internet signal. Ongoing "Wi-Fi connected, no internet" issues
