2019 RAM - Overall height of truck after lift?
Ram_Rover_2019
Hey All,
New here and didn't find a thread pertaining to this so please correct me if you all have a thread going on this.
I want to install the 3.5" Ready Lift with 35/12.50 Nitto Ridge Grapplers. Only issue is the clearance height of my parking garage at work. 6'8'' is the max clearance so I don't think I will fit with this lift.
Has anyone installed this exact combination and measured total overall height from the shark fin antenna to the ground? If so, can you tell me the measurement?
Thanks!
I know you’re looking for an exact match, but I’m at least close. 80” (6’8”) lifting the front 2” and the rear 1” with 33” rubber and the off-road group. Is the 3.5 a leveling kit or a lift?
That being said, I just drove the truck into a garage marked 80” and didn’t hit, which was nice.
Clazer what lift do you have on your truck? Did you do upper control arm's?
Clazer what lift do you have ? Did you do upper control arm's? I would like to do the same thing and still park in the garage.
I don’t think you will get it man, best chance Is probably leaving the rear stock, keeping a similar height tire or 34. It’s going to be close.
I changed the air ride links, put in the Daystar spacers and did mopar upper control arms. Drives really well. That being said, i think the truck could be 1” lower and clear 35’s. It’s going to be tight but I think you can make it. Im waiting on bora hubcentric spacers before going to 37x11.5r18.
Called a dealer looking for a puck style antenna but they said there isn’t one. That would give 2 more inches of clearance.
More details in the thread: The Journey Toward a Bigger Rebel
why do all the lifts for DT models say NOT FOR USE WITH OFF ROAD PACKAGE. All Rebels have the off road package how is everyone lifting them up?
