2019 Ram 2500 Cabin Leak
chesapeake59
Hello,
I am new to this forum and hope to get some help with the seemingly common cabin leak issue.
I purchased a new RAM 2500 and have had off and on issued with water in the cabin.
It started with water leaking at the drivers side A pillar. It now it is in the drivers side rear.
Enough water to cause mold and mildew and keep everything inside wet. Of course, the humidity level is very high.
The dealer states it is the rear window and has offered to replace at a reduced cost.
They will NOT correct any other issues branching from the original leak issue.
This includes the musty smell, interior corrosion, stained headliner and any other leaks.
Its my understanding from online searches, there could be other areas water is getting in.
Rear seals, XM antenna, rear cab break light.
Might anyone here have this same issue and have any proven remedies or recourse with RAM or Stellantis?
I very much appreciate anyone input.
Thanks
Hello,
Thanks
You might have better luck in the Homepage - HD Rams forum. This is the 5th Gen 1500 Rams site.
