riccnick
so what weight range of the triler would you stay with.my Harley is around 900 pounds plus I don't plan on hauling with the tanks full.i only need this to work for 2 years and I can trade my lease in and get a 2500.i know how to haul steep grades and use my engine and trans to do the work instead of braking.
Answer the questions about your trailer plans and your truck and we can literally do the math together, no estimating or guessing involved...
Are you sure the Harley is 900 lbs curb weight? Year, Make, and Model will help us tell you the proper numbers.
Can you post your vehicle loading sticker? (On the inside of your drivers side door, there's a white, red and yellow sticker with the tire info on it and a line that says "the combined weight of all occupants and cargo may not exceed X,XXX Lbs)
Also, what is the year, make, and model of the trailer you're looking at. A "7,500" lb trailer can either be a super heavy trailer, or a light trailer with a GTWR of 7,500 lbs. We need to know the difference. And it's a big difference.
Need the same info for the Harley.
Also, toss your truck info in your sig, it's super helpful with things like this, because now instead of reading your sig to help you with the numbers, I have to ask you if your truck is a crew cab or quad cab, and if it's a 4x4 or 4x2. (Need those answers to run the numbers for ya). It's super handy, there's a thread around here somewhere that kind of unofficially-officially asks everyone to do it, but it's old now so I'm sure nobody sees it anymore.
