2019 Ram 1500 Sport Fog Lights
county_boy86
Driver's side factory LED fog light went out. Purchased new fog lights (driver's and passenger side) from DNA Motoring. Had to reverse the wires as they were reverse from wire harness. Passenger fog light works, driver's side does not. Wires are secure. Nothing is loose. Tried looking for fuses, how ever both fuse panels (under hood and under steering wheel) are missing the diagrams. Have yet to find anything online. Anyone help me out ?
Note: I've updated the RAM 1500 5th-Gen Power Distribution Centers website in this thread yet again. In addition to expanding the fuse descriptions from their esoteric acronyms to their full meaning, they now also include web links to help explain the function of the components that each fuse protects. This helped me a lot and I hope it can help others too. Simply click on the fuse description and it will link to a website with the component's full description.
I found the meaning and description links for almost all of the fuses, but I could use some help with the few that remain undefined. If anyone knows the meaning of the following and a descriptive web link, please let me know:
Supply / Purging Pump
Bank 3 Switch
SW Window
Rear Coolant Temp
Wake Up
I'm also looking for a description of the circuits that Circuit Breakers # 1-4 protect.
I found this, if you go to his actual post there is a link to his google.doc. Hopefully this is helpful
They get power from the BCM. Check L90, WH/OR for voltage under load, if there then the light could be bad, if not then that would point to the BCM, the feed coming from it.
After thought, also check the ground side connections if voltage is present.
Figured it out guys ... thanks for the help. Wound up being the power wire to fog light before the harness connector. Somehow chaffed and broke with out chaffing or breaking the chaff tape on the harness.
