2019 Ram 1500 - Recon LED Third Brake Light
Just posting this in case anyone was looking to replace the boring OEM halogen version.
I forgot to take a close-up of the assembly before I installed it, but the foam gasket that's installed is probably twice the thickness of what's on the old one. Though, to be transparent, I'm not sure how thick the OEM ones are new.
Install was straight forward and the gasket compressed as I tightened the screws (appeared to make a tight seal), but I'll post an update if I have any issue with water intrusion down the road. Also, I didn't have a leak beforehand, this was a purely asthetic swap.
There are multiple threads about it already, including many unhappy customers due to the light getting moisture inside
