2019 Ram 1500 OBD code U11E9 - Fixed!
2019 Ram 1500 OBD code U11E9 Fixed!
Last week I got this OBD code U11E9 “AGS grille shutter malfunction or lost communication.” After doing some research I notice that a lot of people were just changing the grill shutters right away but the issue persisted. I did more research, and found that it the grille shutters and the air dam at the bottom behind the front bumper are linked together and that a lot of times the issue is either a broken wire at the grille shutters connector or a bad air dam. The only repair that I found was one for the electrical connector for the grille shutters and nothing else.
Here’s what I did to repair mine.
  1. Disconnect the bottom air dam to see if the code clears. If it does, follow the next steps. If the code didn’t clear, check the harness going to the grille shutters looks like one of the wires corrodes and breaks near the windshield washer reservoir.
  2. If the code cleared. Leave air dam unplugged and remove 4 nuts holding the assembly, the unit is very light.
  3. Once the unit has been removed, place on a table or workbench for easier disassembly.
  4. Take pictures to make so you have some reference on how everything was.
  5. Remove the four 10mm bolts to air dam.
  6. Loosen the two 10mm on the hinge bracket and slide out. For the motor side, 3 torx screws must be removed, then slide out.
  7. With a medium flathead screw driver, super gently and evenly start prying on the white cap of the motor. In my case, I got a lot of rusty water coming out. View attachment 162105View attachment 162106
  8. Once the white cap is removed, remove water.View attachment 162107View attachment 162112
  9. Gently pull on the electric board and set it a side. The board just plugged in. View attachment 162108
  10. Remove shaft and 4 smaller torx screws inside and with a small flathead screwdriver gently pry upwards the motor and gear assembly inside.View attachment 162109
  11. Remove shaft seals one on each end. In my case, both were hard dried out and cracked. View attachment 162110
  12. At this point, the unit is disassembled and everything should be cleaned and degreased. I clean the electronic board with alcohol and compressed air, no scrubbing on the board.View attachment 162113
  13. In my case, the seals were bad so I ordered them in Amazon for $10. These seals fit perfect. Of course they will be a tight because they are new.View attachment 162114
  14. Grease and assemble. Fitting the shaft in the seals gets a bit tricky, but nothing crazy. Before putting the white cap, add sealant to keep water from coming in. Find someone to help you keep thing aligned.
I tried adding more pictures, but I think I reached the limit.
Hopefully this $10 repair and some dedication helps someone out there that is struggling with the same issue.
Just joined this forum and just like that, found your excellent-detailed- step by step + pics. My 2019 Ram Big Horn 5.7.L popped a check engine light code U11E9-AGS LOSS OF COMM [ Permanent ] yesterday. Have an INOVA 5610 tool which showed this code. I followed all your instructions by first pulling off each connector from bottom air dam actuator and then top air shutters. Reset code faults stored, they cleared but came back. Inspected wiring harnesses could not see any visible rust, wire breaks,/ My tool will NOT RESET this hard code U11E9 AGS LOSS OF COMM/ PERMANENT. The grill shutters are full open and do not move open closed with fresh engine start up. The lower air dam actuator looks new also, air dam wing is fully retracted up. It's beyond my ability at this point have an appt at dealer for Aug 6th earliest. Is there any danger driving around waiting for Aug 6th dealer service ? Truck has 51,790 miles I am original owner. Thanks for any input or Ideas.
I have the same U11E9 code, but an added symptom is that my radiator fans kick on high immediately after starting the truck, and it's loud.
I will start by removing the AAD plug but my question is can I access the AGS wire harness/plug to confirm or deny corrosion without removing the front grill? Or will I need to prepare to remove the grill? Obviously prefer if I don't have to remove the front grill to check if the connection is the issue.
Ram-Jim, my 2019 5.7L fans roar also occasionally but seems linked to Max A/C mode with full cabin recirc air knob settings.
Remove top plastic cover above radiator-coils under hood. 12 pop up snap plugs hold it down. I stuck my hand down between coils and air grille dampers it's tight but doable. At bottom center is actuator plug need to use small flat blade screwdriver tip to pop snap connector unlocking plug [3-wire] Also another plug on air dam actuator drivers side under front bumper area. Turn front wheels full left for more room to crawl under and access. same type of plug.
Does it affect remote start!?
Great timing, and makes complete sense as I ran through some water from Debbie earlier this week when it started. Looked at the procedure and was going to write off checking the other parts and skipped to the AGS. Glad I didn't.
Does disconnecting the AAD throw a code? If that's it and there's no CEL, I may kick the can for a few weeks on the repair with some other projects in front of it.
Hi all, we know this is an old horse but I’m having the same issues…
AGS code will not go away
New AGS motor, New air dam(was full of water and I damaged it after taking it apart)
I checked the wiring found no breaks/ burns/corrosion…
The Lin circuit is reading 12-13v with the motor running. I was reading that 12v there is and indication that the PCM is not working right? Is that true?
This is awesome.
Wondering if anyone has the Wiring harness part number for the AGS and AAD
just out of curiosity as it has not been mentioned in this thread... i bought my truck used and the previous owner had obviously repaired the ruck from front end damage. They did not reinstall the AGS or the AAD components at all. Truck runs great with zero issues, other than the CEL for you guessed it... U11E9. I really don't want to purchase and install these parts. is there a way that maybe with Alfa or Jscan, I can deactivate these in the system? or a way to use a resistor to trick the system into thinking it is there? i did by the AGS "motor" on AMZ for $20 but it not arrived yet. I am going to try and plug that in and zip tie it to the frame so that the computer reads it... any advice is appreciated.
2020 2500 6.7L
2020 2500 6.7L
Today I got into AlfaOBD and Jscan. Was able to mess with AGS and AAD setting. The CEL went away. Drove it for 10 min and it stayed away… then a few hours later went out and started it and it was back! Tried repeating what I did earlier and it would not clear again.
