Edwardpj0nes
- Feb 25, 2024
Hello, wanted to know if anybody might have a wiring diagram or a pin out for the wires that enter the back driver side door. I wanted to tap into the existing wiring with the least amount of modification possible. I plan to connect to the wiring where the factory door plug connects to the rubber boot for the rear door on the interior of the car. I’ll post some pictures. My truck has been broken into a couple times and I’m trying to find the easiest solution to make the car alarm go off when the truck bed cover is open. I don’t really like knock sensors because they go off anytime someone with loud exhaust goes by the car.
I’m installing an alarm sensor to my truck bed cover to help prevent further break-ins. It has normally open and normally closed contacts. The easiest solution I could find is to integrate this into the factory alarm by tapping into the door lock. From what I understand the door lock grounds the signal, letting the car know it’s closed.
So I would connect those two wires to a normally open contact on the truck bed sensor.
Hopefully that makes sense. Any help would be greatly appreciated! I’ll post full pictures of the install with links to the parts I used on Amazon once I get it working. I’m sure a lot of people can benefit from this.
