billydkid5
- May 21, 2020
So I've seen hundreds of people complaining about a similar noise, took to the dealership, unable to duplicate which I think is just a standard response they're using because they don't know how to fix the problem.
Same as other stories, doesn't matter what speed your at, when the RPM's are between 1200 and 1400 and the gas is pressed very lightly, from the rear end area I get a grrrrrrr grrrrrrrrr grrrrrrrrrrrrrr noise. vibration/ humming. when you let off the gas it stops. truck is essentially new, 19K miles. There is definitely a problem. It's not the MDS, because it does it when i go to 8th gear, and also when tow haul is on. it's a 2WD, so it's not that either. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
