2019 ram 1500 battery fluctuation, 12.1 to 14.1
Jac1984
My battery is fluctuating and almost making the truck die even driving with full load. I trickle charge the battery and it worked fine for a week and then it started acting up again. Can anybody help me? Should I buy a new battery or is it a different issue?
bigdodge
Happy Ram Owner
replace the battery
23RAM
Canada
You didn't provide any details about your truck like age, mileage, etc. so it could be anything. Bad grounds, loose connection, etc. It could also be a charging issue where the battery is not recharged properly. Or the battery is old or weak and not holding a charge.
Goatmann
Florida
get the battery load tested. As posted above, most likely have to replace it.
