2019 model brake fluid low warning at startup
keanezheng
During this past winter, I have seen brake fluid level warning at start ups especially the morning. I checked the fluid level, and it seems normal.
The warning stays on for a few seconds, as soon as I start driving, it goes away.
Anybody has the same issue? I flushed the fluid about around 30K miles and now the car has 45K.
Is it a bad sensor? It seems easy to replace
Also I do have a ABS DTC C2206-00 and I could not erase with my TOPDON carpal OBD scanner.
Is it a sensor issue or an ABS issue? I couldnt feel anything mechanically when I brake.
IIRC, I had to use SGW bypass cable to clear ABS DTC`s.
The C2206 could be caused by the ABS module?
C2206-00-VEHICLE CONFIGURATION MISMATCH
NOTE:
If the BCM has been serviced make sure that the Restore Vehicle Configuration is performed before
continuing with this diagnostic procedure.
Theory of Operation
The Anti-lock Brake System (ABS) is not matching the vehicle configuration information stored in
the Powertrain Control Module (PCM).
When Monitored and Set Conditions
When Monitored: This diagnostic runs continuously when the following conditions are met:
Ignition on.
No under voltage DTCs.
Set Conditions:
The vehicle configuration data has not been learned or has changed from the Powertrain Control
Module (PCM) broadcast over the CAN C Bus.
Default Actions:
Anti-lock Brake System (ABS) indicator light illuminated.
Electronic Stability Control (ESC) indicator light illuminated.
ABS disabled.
ESC disabled.
Possible Causes
ANTI-LOCK BRAKE SYSTEM (ABS) MODULE VEHICLE IDENTIFICATION NUMBER (VIN) RELATED
DTCS
POWERTRAIN CONTROL MODULE (PCM) DTCS
ANTI-LOCK BRAKE SYSTEM (ABS) MODULE NOT INITIALIZED
Always perform the PRE-DIAGNOSTIC TROUBLESHOOTING PROCEDURE before proceeding. (Refer
to 28 - DTC-Based Diagnostics/Standard Procedure) .
