2019 limited ceramic coating
Bee7_ivan
Great job. I’m using CQuartz this weekend hopefully
Kxlexus
Kentucky
I used CQuartz UK on my 2019 Longhorn and it looks like a black mirror
Kxlexus
Kentucky
Yes I did 2 coats. Be sure you have adequate lighting and be absolutely certain you get it all wiped off. I failed to wipe off or rub in a few spots the first time I did my truck. It looked great in my garage but the spots were noticeable, to me only, once I moved it outside. It bothered me enough that I added a lot of lightning to my shop then started all over again
Bee7_ivan
When did you add the second coat . Instructions don’t make sense . It says add a 2 coat within the hour . If it’s past the hour, wait 24 hours.
So does that mean I can add a coat then add it it right after ?
Kxlexus
Kentucky
I did the second coat within an hour. Of course it takes more than an hour to completely do a coat on the whole truck. The way I got around this was to do 1 coat on a few panels then do the second coat on those same panels before moving onto another group of panels. Example; do a coat on the hood and front fenders then turn around and do a second coat on the hood and front fenders. Then move on to the passenger side doors and apply both coats before going to the drivers side doors etc...
Bee7_ivan
I’m going to do exactly what you did. Did you too it with Carpro Reload after or did you wait the 24 hours?
Kxlexus
Kentucky
I waited a week or so, until the first time I washed it, to use the Reload
Rich51
I have never done ceramic coating before is it really that much better than not? I have read good things but now having my truck for almost a year would it be worth it?
Kxlexus
Kentucky
That is something only you can answer. I would do it again on my truck but I was able to put it on by myself. I wouldn’t spend the hundreds of dollars some shops charge. Although I understand why they charge so much. I wouldn’t do it cheaply either
