Couchsachraga
- Aug 12, 2018
One of the things I like most about air suspension is for the ability for it to keep the vehicle level when towing, loaded, etc.... My truck has a significant rake (like you'd see in an empty truck) all the time; I'd prefer it be level.
I've also noticed that the rear drops less than the front.
Some measurements (on a level garage floor); floor to wheel arch I measured to tires to wheel arch as well, but this seemed easier to reproduce and easier to measure)
Offroad (highest setting)- Front: 38.5", rear 40.5"
Entry mode (lowest setting); Front 34.5", rear 37"
So the front moves 4", rear is 3.5"
The rake is fairly significant; over a 2' level (on the bed) it is about 1"!
I'm still running the stock tires (too frugal to replace perfectly good tires, but I look forward to putting something a little bigger on when it is time. I might even go duratrac.
Other than the 12" screen flaking out at times (changing radio mode, dropping a call; neither frequently) I really don't have any complaints - rides nice, ridiculous acceleration (3.92 rear end helps), and no issues (again, other than the 12" screen and the non-levelness, but I suspect that is WAD (works as designed).
Editted to add - with my last vehicle you could get "Johnson Rods" for more lift. It appears the following might do the same for the Ram... anyone have experience with the company?
https://www.revelperformance.com/lifts/2019-ram-adjustable-air-leveling-links-set-of-four-links/
I'm not really looking to lift (well, maybe a little , just level it out better. I suppose I should see if the factory rods are adjustable... hmmm...
