MacDuff
- Sep 18, 2018
Just installed 35 inch General Grabber X3's and Fuel Ammo 18" wheels.
Tire size 35x12.5x18 Very happy with the Generals. Coming off BFG KO2's that were about 1/2 worn and I was surprised that the Generals were actaully quiter and rode softer (20" wheels with KO2's). I'm sure they'll get louder as they wear.
Wheels: Fuel Ammo 18x9 -12mm offset
Rough country 3.5 inch lift kit. Definitely had some back and forth on getting the ride and level correct, but happy with the end result.
I had significant rubbing on install when turning. The front wheel wells had to be modified at the rear lower spats to accomodate the 35's.
I bent the sheet metal under the spat and re-drilled the plastic liner to re-use the existing hole in the sheet metal. Alos had to heat and re-mold the lower spats to gain a bit more clearance so they wouldn't pull out the clips.
