2019 has knocking/rattling sound
Ram4141
Hello,
I have a 19' Ram 1500 4x4 CC with about 33k miles on it. I like on a gravel road and every since I have owned it I have gotten a rattle/light knock in the front end when driving on gravel roads or rough roads. I have taken it to my local dealer 3 times now and they say they can't replicate the sound. There are no gravel roads near the dealership to make it make the sound. I asked them if they looked at the sway bar and I was told all suspension components are tight. This sound drives me nuts. Has anyone else had this issue?
Thanks,
Ram/Tun
People complain about sway bar end links. Check them out. Also lower ball joints
Ram4141
Is there any way I can check them? I have no idea to tell if they are bad.
ArtieD
New York
You can try to grab the sway bar and shake it around to see if there is movement , Also jack the front tire off the ground ,jack from frame not on any of the control arms , grab the tire and shake it around see if anything is moving side to side , just make sure truck is chocked at rear and is secure on jack , use a pry bar under tire and see if there is any up and down movement you may need a second person, if there is anything loose you will definitly see or hear it
Good luck
