To add to the above, same thread, pg 24/24:
‘I’ve had my 2018 Rebel for just over a year and last Oct when the temp started to drop overnight down to 2 degrees C (I’m in Vancouver) The next morning, front end was sitting low and up came the warning that air suspension system need immediate service. I was shocked and called the dealer, they told me to warm it up and turn the truck on and off and see if the message cleared itself, it did and once the truck was warmed up the suspension worked fine. They said with the drop in the temp, the sensors get tripped up by the drop in the air pressure in the system and not to worry. All winter long, every few days, I’d get the message, I’d warm it up and restart it and thought this was stupid. We recently had a week in the mid mid 20’s things seemed fine and then it dropped to +9 and I got the warning again, only this time it wouldn’t go away or raise the front end up. Limped it home and googled the issue and found out about the fuse and all the similar problems out there. Funny how when I was researching the truck and searched for known issues, this never came up. New fuse made things work again and I took it to the dealer over Easter weekend, put the blown fuse back in when I dropped it off and expressed my concern about so many people having this issue. After a bunch of tests they replaced the compressor and fuse and I asked them why the compressor was blowing the fuse they said something about water getting up in there and freezing. I’m in Vancouver, it was +9 when this happened and +14 this weekend, the worst we get is a few days a year where it drops below freezing, maybe -7 max. They didn’t seem to have a answer for me. I only have 15K Kms on my truck and will have to see if they sort out this issue before the warranty runs out. I thought I was buying a solid truck that could take anything I could throw at it. They gotta fix this if they are failing in my mild climate too. I can’t imagine this truck back where there is real winter.”
End of copied post, dtd 4-24-2019
So it could happen in milder temps as well it seems. Maybe read the thread for more info.
