First question is about the paint job. Down on my lower rear panel there is an area about the size of a 2" circle where the paint is cracking and you can see the white primer showing. Plus there are 2 cracks in the paint leaving the circle to about 3" long now. Would this be a warranty issue. Do any of you have anything similar on a 21.
Second question is about the clear coat. Someone dragged something across my drivers door leaving 4, 2"-4" smudges about 1/4" wide in a straight line with space in between each mark. It's not a scratch and primer isn't showing, but it is very noticeable and annoying. What would be the best way to buff that out. Thanks
