19 limited with air ride lift questions.
Jkurz
Have a limited with the air ride.
thinking about to putting a lift on it.
does this delete the air ride, or can you keep it?
Thinking and something to going 38/39
would the air ride need to be taken out or just disabled!
Thanks.
19TXLimited
You want to fit 38's or 39's on an air ride? If so, then I think you are out of luck. I believe there are a couple 6 inch lifts which maintain the factory air ride, but not sure you're getting that big a tire under them.
For a simple level you need leveling links and a Day Star spacer kit and from what I can tell you would then be able to fit 35's under her.
Good luck in your search. Also, there are several full threads on lifting with air suspension. None of these threads are very easy to follow, but they are there if you have the time.
clazer
You can probably do it with a 6” BdS or RC and some fender trimming if you ain’t skeered. Need to keep the offset as close to zero as possible to minimize scrub. Biggest I’ve seen on here with functioning air ride is 37”
