M
Mdegen93
Guest
Anyone know if the above setup should fit? Roughly 34” tire and a -12 offset
Will do. Just ordered them today should see them in a couple weeksHello, I just received my new Laramie, Air suspension, Offroad 4X4. Can you report if you tell me if these fit? I'm very interested in buying wheels and tires for my truck, but I'm getting confused with Brake Calibers and what the largest tire I can install without any rubbing.
this is a 33x12.50r18 on 18x9 -12 fuel with 2 inch level. Tires measure 32.75" versus 33.5" for a 305/65Anyone know if the above setup should fit? Roughly 34” tire and a -12 offset
Also I know 18’sHello, I just received my new Laramie, Air suspension, Offroad 4X4. Can you report if you tell me if these fit? I'm very interested in buying wheels and tires for my truck, but I'm getting confused with Brake Calibers and what the largest tire I can install without any rubbing.
so really it’s only about 1/4” on either side bigger. I should be goodthis is a 33x12.50r18 on 18x9 -12 fuel with 2 inch level. Tires measure 32.75" versus 33.5" for a 305/65
Do you have a side profile shot. I wanna see the pokethis is a 33x12.50r18 on 18x9 -12 fuel with 2 inch level. Tires measure 32.75" versus 33.5" for a 305/65
A little more than 1/4" but less than half inch on each side.Also I know 18’s
