18" Black Rhino Fury Matte Gunmetal (Air Ride Limited)
TurboEd
67470797_2447065798861979_8674559071367462912_o.jpg67438117_2447066088861950_3401585751647846400_o.jpg67500003_2447065812195311_8818769693616635904_o.jpg
First real mod. After much debate decided on 18" +12 offset Black Rhino Fury in Matte Gunmetal finish for my ivory white 2019 Limited. "Normal" AirRide mode for the pictures I presume (shop took pics). Upgraded from the stock 20" rims. The Bridgestones were swapped for 275/70/18 Duratracs. Currently 40 psi all corners. It is as I expected from the larger sidewall, very happy with the overall drivability of this setup. Usually looks darker than these particular set of pictures portray. Stock suspension. No lift. Zero rubbing. Chrome diet underway.
My goodness that is a really sharp looking wheel. Did you need hubcentric rings with it ?
Very good question. Thanks. Not to my knowledge. I ordered through a friends shop and they took care of everything. They were very communicative but this issue never came up. It rides very well. I will be on the lookout for symptoms. These were just installed. But so far no rattles and no wobble. Appreciate the comments.
No problem, thank you for sharing yet another 18” wheel option that looks great. :)
Typically you don’t need them, if you tighten the lugs correctly (evenly) the wheel should center itself.
Good looking truck.
Thanks
I didn't realize 18" rims would fit on a 2020 Limited w/Air Suspension. Are there concerns about clearance on some wheels? I have 22" wheels but can't stand the look.
Several folks have done this and been much happier with the ride and the look.
Really sharp looking wheels. Excellent choice
