18” aftermarket wheel issues
Curto
Hello! Newbie in here and just bought a 19 Black on Black Laramie with 22” wheels . Bought a set of Anthem 18” to mount winter rubber to and be damned if they don’t hit my rotors! Crap! Anyone have this happen? Will 20” wheels be an issue if I return and go from the 18’s I tried? Mounting plate should not be an issue I hope as I don't want to put spacers on. Same tire diameter and width going on , just not 22” winter tires!
It's literally hit or miss with 18" wheels and the brake calipers. 20s work no problem. Finding a set of takeoff OEM 18" wheels is your safest bet with 18's, or do a search on here for the guys that have found 18" aftermarket wheels that work.
Thanks for response. The program I bought my Anthem wheels is a member loyalty type deal. Kind of have to stick with them,so I will upsize to 20's i guess. Little more expense but will solve the issue i guess. Thanks again.
Op where are you located ? I maybe able to help you out wheels wise. :)
