Here's a write up on how to remove the radio. In the 2nd picture you can see the green back of the 12v plug (on the right side). You should be able to remove it from behind once out although I've not messed with it. You could probably remove it without disconnecting any of the wiring with just the top play in the wires. I'd just be careful to not put any strain on them.
The only issue I've really had with the Limited was that the "-" button sticks on the trailer brake controller and after it sticks in for ~30 seconds it throws a "service trailer brake controller" message. I figured out I could pop it back out with the corner of a credit card so I've been...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
