1” air suspension /programming change, alignment?
Milkman7768
I just had the dealer change my air suspension settings to 1” over height on my Limited.
Do you think I should have it aligned? Or does anyone thing I am still in the “good range”?
Thanks!
Thanks!
Wait, what? How?
Any information on asking/cost for the dealer to reprogram height?
Thanks!
How’d they do it?
How much?
Definitely want to find out as well. I've been wanting to piece together the offroad package.
Yes I’m curious to see how much they charge.
It all done. Lift was about 90.00 in labor. I would have to go back and look at the bill.
Alignment is done too. It was pretty far off in normal mode (now one inch higher)
So for those of you riding around in off road 1, around town daily, I would gather you are really stressing the tires. The camber was out quite a ways. Toe was out too.
Steers perfect now.
I love it, should come Factory this way
Steers perfect now.
Was the height adjustment done by reprogramming?
would like to know too! Any one ever mesure from ground to fender? Would be interesting to see the difference between all truck that are ''supposed '' to be setup the same. I had my ASCM replaced under warranty and now my truck is higher than before on normal height. Good thing I notice before getting into my interior condo garage.... I used to get through the door on normal mode, now I have to enter the garage in aero.
TTT... how/how much to get the dealer to set the standard heigh to ORD1?
0$ for me as they screwed up setting my truck too high when reprogramming my ASCM. Guess you can ask you service guy if he is willing to give it a try!
