net is not a audiocontrol dealer......so i would not take their advise on those products Net is okay but they don't know it all. if anything it would need load resistors to make it work. but what you really needed was a lc7i pro with built in load resistors if that is the route you want to go.
LC7iPRO 6-Channel Line Output Converter w/AccuBASS
AudioControl brings you our most advanced line of LOCs yet. OEM integration has never been easier with the host of intelligent built-in features like LMC™ (Load Matching Circuit), allowing even the most finicky factory sound systems to no longer be an obstacle to great sound. Installer-friendly...audiocontrol.com
all your work will be done under the drivers seat.Yeah the lc7i pro I got has them built in already but no t harness so I guess I have to cut up my wires, is there any diagram available to know what the pins for the speakers are and any idea if the dash speakers are on their own channel or wired in with the fronts?
if you have the base radio the dash and the front doors are on the same channel it's not a 6 channel radio and you will need to bypass the ANC
if it a base radio get this and it should plug in line under the seat if it don't just return it amazon don't care lol.https://www.amazon.com/dp/B0B1H2QWWY/ref=sspa_dk_hqp_detail_aax_0?psc=1&sp_csd=d2lkZ2V0TmFtZT1zcF9ocXBfc2hhcmVkall your work will be done under the drivers seat.
