‘25 base sound system upgrade
jpbr2025
Called up net audio today and they don’t have a t harness for my head unit, i mentioned i picked up a lc7i and he said it wasn’t gonna work. Anyone know any alternatives? Seems like these 25s are being a headache
net is not a audiocontrol dealer......so i would not take their advise on those products Net is okay but they don't know it all. if anything it would need load resistors to make it work and you can still use what you have with the correct add-on resistor there is 3 you will need the correct value unless you have the PRO.
what you really needed was a lc7i pro with built in load resistors if that is the route you want to go. the standard lc7i will work as well as the pro but ya need to know what you are doing to get it to work. i live in NC i guarantee i could make it happen with almost any AC product.
net is not a audiocontrol dealer......so i would not take their advise on those products Net is okay but they don't know it all. if anything it would need load resistors to make it work. but what you really needed was a lc7i pro with built in load resistors if that is the route you want to go.
Yeah the lc7i pro I got has them built in already but no t harness so I guess I have to cut up my wires, is there any diagram available to know what the pins for the speakers are and any idea if the dash speakers are on their own channel or wired in with the fronts?
all your work will be done under the drivers seat.
if you have the base radio the dash and the front doors are on the same channel it's not a 6 channel radio and you will need to bypass the ANC
Yeah it’s a base with the 8.4” uconnect 5 screen, I believe I don’t have any anc I only have the two mics above the driver and passenger seats
if it a base radio get this and it should plug in line under the seat if it don't just return it amazon don't care lol.https://www.amazon.com/dp/B0B1H2QWWY/ref=sspa_dk_hqp_detail_aax_0?psc=1&sp_csd=d2lkZ2V0TmFtZT1zcF9ocXBfc2hhcmVk
you cut the speaker plug in the bypass harness then you have a input for the lc7 and you can use the other side if the "t-harness" tie into the factory speaker wires.
i assume you adding amp's and plan on changing speakers/sub.
may recommend some items
Amazon.com
i got to go do some thing's i'll check back in the first pic below is my truck i think i know a thing or two about A/C products i have the old lc7i had a lc2 and MANY other of their stuff over the years.
this good wire for what you want to accomplish
been doin mobile audio for 30 years i have done 3 ram's but not a 2025 yet
