Off Road Mode
RebelRam2019
Virginia
Curious to know if there is a way to set to Off Road Mode and hold it there and not automatically lower when you speed up. Same question for any of the height levels. I have a 2019 Ram Rebel Crew Cab. Any info would be greatly appreciated. Thanks!!!
I saw a YouTube video where a guy raised it to the max height and then pulled the fuse so it stayed at that height.
Interesting, but still want to be able to adjust it. I just have a couple place I like to go where there are short roads that connect the off road spots and I can see it being a thing to have to readjust all of the time.
I was looking through my UConnect the other day, I thought I saw something in a submenu about turning aero mode off. Might want to thumb through some pages under settings.
I saw that too, I'll give that a try, but not sure that's going to work. Thanks for the suggestion.
Similar boat as you - '19 Rebel here and after jogging through all the menu options, without pulling a fuse, I've seen you can only manually choose between aero and normal at all speeds.
Anything greater than 27mph in Off Road Height will self lower to normal, anything faster than 17mph will self raise from entry height (either up to aero or the last setting if entry mode was hit with the keys)
... If you find or devise a solution, definitely post up!
The closest possible option I saw a tutorial on was to use a relay triggered by a spare home link button to 'disconnect' the fuse (f70?) Temporarily when needed.
Exactly what I found as well in the last day or so. Sadly, no solutions as of yet. Please post as well as soon as you find anything. So the challenge is out there. I know there has got to be a smarter guy than me out there that can not only figure it out but put it into directions that I can understand and replicate without voiding any warranties. And...Go...
Tried it and sadly it did not work, but was worth a shot. Thanks for the suggestion.
