Eibach pro truck stage 2 R
I know this is the Stage 2R post, but I finally got my Stage 2 on last week. Drove it for about 150 miles now, much better than 77k mile OEM shocks.
Before0 Miles150 MilesWanted
Driver Front39.7541.540.2540
Pass Front4041.540.7540
Driver Rear414240.541
Pass Rear41.254241.2541.25
My UCA ball joints are shot, so while I'm replacing those I'll adjust the fronts. Before I installed I had a 1/2" spacer in the driver rear, but I left it out. I'll put that back in too to make everything pretty near equal.
Yep..I'm running a 1" LR & 0.5" RR spacers to L/R balance.
So far, I'm about 500 miles on the Stage2 COs and 200 miles on alignment..and holding tight at 40.25" at all four corners.👍
Unfortunately, his astroturfing antics are not fair to other paying vendors and he has dodged any sort of subscription, even a $25/year member sub despite multiple contacts by the site staff.
For the life of me..where do I subscribe?? I can't seem to find it🤔
**Edit..found it, subscribed👍
(I've been wanting to pay up and help the site for a while..thanks for the "kick" to do it😀)
My Timber Grove bags lifted the rear 0.5" even at 5 psi so technically I'll be the same on the rears after I put the 0.5" spacer back in. Overall 3" front, 2" rear lift I like having just a bit of rake as it takes away the appearance of being nose high. With how round the front of these trucks are it looks like a whale coming up for air whenever the rear sags.
I got my truck back yesterday. I changed the rear Eibach springs back to the ORG/Max Tow springs that came as OE. Also added Hellwig rear sway bar. Rotated and balanced the big beast tires and the returns are huge. Ride is much better than prior. Hellwig is great but I'm attributing this to rear springs. Only down side: The rear went up about 1/2" from my tape so the front is now down a little more than preferred.
I'm going to tow a load this weekend so I'll see how much droop I get in the rear. But, I'm probably going to have to lift the front up at least 1/2"-3/4" to make it look right to my eye. I parked in a spot that's little low in front but this still shows the rear up balance.
Good news is...leveling up the front Stage2 COs is very easy...just jack up the front of the truck and crank up the front adjusters..wheels stay on even. I highly suggest spaying the strut threads above the lower spring collar with WD40 as it makes the adjustments much smoother and easier to do.
Are the 2R rear shocks a bit softer for road use compared to the standard 2 rear shocks? I've seen some conflicting info about this. Found a great deal on some brand new 2R rear shocks that I jumped on but am questioning if I should go with the 2 series instead. I mainly use the truck for road only with minimal towing but prefer a softer, more floaty feel, so I opted for the 2R rear shocks.
Also curious if the front coilovers in the 2R kit are the same exact coilovers that come in the regular 2 kit?
Following. The 2R kit looks like my best option. I like the Fox kit, but this is more within my budget. Mostly street driving. I've had it 2 years and haven't taken it offroad yet. Though I intend to if I get this kit.
What are you guys paying for the install including the CA's?
Just curious: Do you guys expect a fair amount of rust on the body of the shocks/coilovers after less than 6 months? Winter/salt or not, just curious what others are experiencing? I took off my 295/70/18 Wildpeak AT3s and I'm going to run the OE Wildpeak AT4W (22"s) and see how the truck handles/rides as comparison. When I changed the wheels I noticed a decent amount of rust. I'm going to take a 8 hour roundtrip drive next week to compare ride and mileage.
My Stage1s had quite a layer of surface rust on both the front and back pairs.
I took them off and scuffed, cleaned, and sprayed them with a single stage Grey primer/paint..and it looks great after a second winter.
I just put Stage2 COs at the end of this winter and I'm sure they will rust up also..it's not really possible to paint them easily without disassembling them.
Eibach's struts & shock ride and handle fantastic..but the finish absolutely sucks if you're in a salt use state!
The rust issues are discouraging considering how much the parts cost. Does this seem to be a problem for people that aren't in an area known for rust? I'm in CA, no rust issues here. I wouldn't mind rattle canning the shocks, but don't think the springs would look as good.
As discouraging as it is, they're not the only suspension company that has this issue. In the Jeep world, the Rancho 5000 series is known to have poor paint coatings. Many have re-painted them before installing.
It’s a pick your poison thing.
Aluminum struts won’t rust, but you can’t adjust the coilover perch while they’re on the truck because the threads will booger.
Steel bodies you can, but coating the threads isn’t ideal so they could rust.
I personally won’t buy another set of coilovers that can’t be adjusted on the vehicle; such a game changer for fine tuning things!
Exactly. Spent about 45 minutes yesterday fine tuning the truck's front end. Much easier when you don't even need to take the wheels off. Although my hands are killing me.
