TRX Shifter swap
you need to read codes with jscan or alfaobd, all modules to see what isn't happy.
you can't go by the warning lights on the dashboard to tell you what is incorrect.
did you change "shifter type" in the BCM vehicle settings?
Hmm. I bought Alfa OBD. I am going to try this again. The only question I have is, would the fact that it is a TRX Shifter be an issue? Since the TRX has a different transmission?
I am going to try this again on Sunday. Since this will make or break whether I keep the truck, or trade it in for a newer Sport GT. I will take photos so you can tell me where I went wrong.
Thanks.
shifter should work, you just have to configure the BCM correctly.
and this is where you really need a factory truck config to copy the settings from. you can try to guess at them and you might get lucky, but its tricky.
assuming its wired correctly you for sure need to configure the "SHIFTER TYPE" in the BCM.
then start reading codes, and see what kind of errors are reported, and then you can start chasing them down one by one until you get a "green light"
TRX / console shifters have been done, it will work.
So have TRX paddles/steering wheels.
Please take lots of pictures when you do yours.
This might eventually be on my list of things to do in my 22 Limited. I already have a TRX wheel and paddles shifters and my TCM has an GT firmware on it already. I don't even use the extra space the console has as it's awkwardly sized imo.
So we could just add the paddle shifters without the shifter ?
I am in the process of doing this swap on a 22 limited. Went with a trx shifter and a g/t sport dash 4x4 switch. Since the trx console is already wired for the shifter I went with a floor console extension harness off ebay which is the same as info tain ment offers. I then plugged that into the dash side and console side but depinned that extension harness for the 5 wires to run up to the original dash dial selector. From there I used positaps to connect the 5 needed (minus the 6th ground since already in console/dash harness). For the 4x4 selector on most of the non-gear selector versions it is a different harness plug which is the same as the led footwell lamps in most dodge which I stole my sons 2012 charger one and then positapped into the 3 wires to convert it. Now nothing works as in the shifter and the 4x4, I get an error message on the cluster for service shifter and service trailer brake. I changed the bcm config shifter style to the 5 pos polystable e shifter (PS5) but that did not help. For now, I suppose I will be verifying connections but figured I would share.
part number for the 4 pin harness plug on MOST non dial shifter 4x4 switches is 68490847AA. There are some variants that use the same 12pin plug depending on the variants of the 4x4 system you have. For myself I have 2wd, 4wd auto, 4 hi and 4 lo so those are 4 pin plugs. I have seen where a 2wd, 4 hi and 4 lo only ones use a 12pin for example.
I am in the process of doing this swap on a 22 limited. Went with a trx shifter and a g/t sport dash 4x4 switch. Since the trx console is already wired for the shifter I went with a floor console extension harness off ebay which is the same as info tain ment offers. I then plugged that into the dash side and console side but depinned that extension harness for the 5 wires to run up to the original dash dial selector. From there I used positaps to connect the 5 needed (minus the 6th ground since already in console/dash harness). For the 4x4 selector on any of the non-gear selector versions it is a different harness plug which is the same as the led footwell lamps in most dodge which I stole my sons 2012 charger one and then positapped into the 3 wires to convert it. Now nothing works as in the shifter and the 4x4, I get an error message on the cluster for service shifter and service trailer brake. I changed the bcm config shifter style to the 5 pos polystable e shifter (PS5) but that did not help. For now, I suppose I will be verifying connections but figured I would share.
part number for the 4 pin harness plug on all non dial shifter 4x4 switches is 68490847AA
Here is my wiring routing:
Dial gear selector to trx/gt shifter console harness
Pin 1 rd/ye to pin 13
Pin 6 wh/og to pin 15
Pin 7 wh/bn to pin 16
Pin 8 ye to pin 10
Pin 9 gy to pin 9
Pin 10 bk (ground did not need)
4x4 buttons:
12pin stock to 4 pin gt/trx/rebel/2500
Pin 5 bk to pin 2
Pin 6 og to pin 1
Pin 7 rd/ye to pin 4
Update: It works! ohm checked all my connections and found some I had to redo with the positaps not seating all the way.
I did resolve the trailer brake and shifter error ones from earlier just forgot to plug back in the trailer brake. as for the shifter error, I cleared the bcm/tcm codes and key cycled to resolve. shifter works and all gears function etc after testing. Manual shifting displays M1 on dash and on the heads up display. Will continue messing with settings once I get done swapping in the 12" gauge cluster.
Well after testing and i realized the auto start stop button is not doing anything, the other buttons work for 4x4 so trying to figure this one out. Will also try and figure out the drive modes for the gt sport buttons, but confused why the auto start doesnt work. Tried everything, hood closed, seat belt on and driving, the 3 requirements to disable enable it but nothing happens when button is pressed.
Maybe something is up with Tow/Haul Mode, which does cancel out AutoStart/Stop?
Is it shifting normally in A1-8 Mode?
I will take a look at that today. Everything seemed fine including on the digital cluster when cycling to the start stop page it showed ready. Hoping it is not the switch I went with really hoping I can get all the drive modes to function at some point, didn't want a standard one so went with the rarer of them all.
Still have not been able to determine whats up with the start stop button not functioning. tow/haul is not a factor. Thinking there must be settings to change in alfaobd for the change of the selector type but cannot find any info out there in regards.
UPDATE: I was able to resolve the auto start stop physical button issue. The dash transfer case switch version I chose turned out to not be compatible with pre 24 trucks unlike what the seller claimed. I got another one without the g/t drive modes and worked instantly, so no TCM flash required.
Part number I went with and works 100% is: 68516794AA
Can you now upshift and downshift like the GT ? or just hold the gear like before.
Ill have to try next time I take it out, but I do not believe it shifts when moved over into manual mode, it was only disabling auto start, but then again, I may not have changed that setting in the bcm. Also, not sure if the g/t console shifter does manual with the paddle shifters. I only cared to get prnd to work and auto start button on dash to work which I did. All the other perks to the console shifter and paddle shifters I am not after. It may come down to the G/T TCM file to activate what you're seeking which I do have one from Jimmy07 that I have not used yet as originally was trying to resolve the auto start button, but would make sense as well to get the console shifter and paddles to function as they do in a G/T. Take a look at my other thread on this for more info on the tcm flash:
For those of us without eTorque, has anyone found a solution to removing or covering the auto start/stop button on the replacement 4x4 shifter panel? Really looking at doing this swap but want it to look clean.
do you have descent control + axle lock?
wondering if you can mix n match from a HD, ie. use the plastic front cover from a 2500 panel and install your circuit board into the housing?
maybe the center 4-button area detached from the surround plastics.
Can you not get one without the auto start/stop button?
I don't believe you can since every GT came with auto start/stop. My truck does have axle lock and decent control
If you don't have e-torque, then you don't have auto start stop. My 2020 Built to Serve has every option but auto start/stop.
  • Back
