Need your expertise for my wheel/tire setup
Maverik259
5thGenRams Supporter
Virginia Beach
Ok so for this money burning a whole and it needs to go before my wife allocates it elsewhere.
I’ll caveat this as I’m brand new to trucks. So having actual tire size options is running my brain ragged.
My desire. No rub. Prefer no trimming but if I have to learn what this zip tie thing is or bust out my dremel so be it.
Plan: I have a ‘26 with air ride. Bought the Revel level kit with 2.5” spacers.
20” Fuel with offset options of -12, 1, 20?
NITTO G3 P275/65/20 or LT285/65/20?
Tires are going to be Nitto G3. Prefer P rating as I do a lot of hwy driving but want my truck to look like a truck and when needed behave like one. So for sizes I want as close to 35s as I can get. Unfortunately for the P rating the tallest I can go is 275/65/20 which is 34.2” but 10.8” wide which is 1/2” narrower than oem. I can live with this but don’t want to look like bicycle tires but I know narrower does handle better in wet and snow. And it rains a lot here.
My other option is to just get the actual size I want which is 285/65/20 but this is an LT tire and weighs 13lbs more than the 275/65 and is obviously an LT vs P and all that entails. So again I do mostly hwy and I don’t tow anything (maybe one day I’ll have a boat, maybe).
Will the LT be that much more rough compared to the P? If anyone has experience with both would be great. I may very well be thinking too much int this and shouldn’t get the size I want. It is a truck and 13lbs per axel probably won’t be noticed by me but this thing already sucks at mpg (not that I really care but I would prefer to not negatively affect it without gaining something back).
Anyway, any experience from you seasoned ram guys with aftermarket set ups would be great.
So which offset based on those tire options and which tire?
I have 275/60/20 on mine, stock height, no issues. My advice - if you are adding any lift, don't be conservative. If you care that much about mpg, you're never going to be happy with the look.
Not really an answer to either of my questions but appreciate a response!
I don’t want a stock look so I’m trying to see which to go with to achieve my goal which is a flush look.
So you’re running 275/60/20 on oem rims I assume.
Nope, Fuel Heaters w/Cooper Discoverers, as called out in my sig. I realize it didn't directly answer your question, just trying to give you something similar to what you are looking at, for comparison.
Sorry I use the app and it doesn’t display signatures.
But cool so you’re on fuels as well. I like the heaters too. What’s the width and offset of the wheels?
Wasn’t aware that the app didn’t display signs, not even if you rotate the screen? Anyway, 20x9, +1 offset.
I replied in other post, but here's mine 285/65R20 34.6 X 11.2 w/ 20X9 0 Offset. I think the LT tires ride great. Choice of tire will also matter besides P or E. Some ride harsher then others.
You’re looks exactly what I’m aiming for so I think that answers that. Remind me what lift are you on.
Looking forward to pics
Was struggling to not spend the $$ on some Vossens cuz I kept going back to them but couldn’t find them in stock or in the offset I needed so figured it was fate lol.
Went with the 20” Rebel 6 +1 in Terra Bronze with Nitto G3 275/65/20.
Those look good in bronze
