Driver side taillight running light not work
Furbz217
Michigan
Driver side tail light running light not working it started with it flickering and just went out, I bought a used replacement but the same problem. I went to the dealership today they gave me a few code. Just trying to see if anyone experienced this problem and maybe a area to check for the ground connection and solve this problem, TIA2372.jpg
Driver side tail light running light not working it started with it flickering and just went out, I bought a used replacement but the same problem. I went to the dealership today they gave me a few code. Just trying to see if anyone experienced this problem and maybe a area to check for the ground connection and solve this problem, TIAView attachment 213267
B21F9.
FUSE OPEN
FUSED B(+) CIRCUIT OPEN OR SHORTED TO GROUND
POSSIBLE CAUSES
BODY CONTROL MODULE (BCM)​
B2143.
UGDO ENABLE CONTROL CIRCUIT SHORTED TO GROUND
UNIVERSAL GARAGE DOOR OPENER (UGDO) MODULE
Possible Causes
South Main Auto found corrosion in the wiring that caused trouble with a tail light.
Sometimes the copy and paste gives weird results, apologies for that.
B21F9.
FUSE OPEN
POSSIBLE CAUSES
B2143.
Possible Causes
Thanks a lot it was the same problem same style bypass. Thank you sir
