B pillar applique replacement
1979Shawn
I want replace b pillar appliques cause their scratched and their textured so no buffing them out. Looks real easy to remove and install , but i'm hesitant cause I feel 3 small plastic clips will obviously break when pull applique off and pieces could fall inside the door? Don't want have pull door panel off to get the plastic pieces f their going rattle around in there? Anyone replace them and have this happen?
I just replaced all my pillars including the b pillars not hard at all there is a video on YouTube from weekend garage that I followed then all u do is take off the seatbelt slide bolt put new b pillar back on and your done took about 30 minutes again not hard at all
Thanks for the info👍... So the 3 plastic snap clips on the pillar panels when you removed them and they probably broke, wasn't a concern falling down inside the door?? I'm guessing not, just want make sure.
nope pull straight out and u will be fine take out bottom pillar first then top it slides off then remove nut and put new one on and replace b pillar
