gomango392
For anyone interested, we have stage 2 kits in stock for the 19-24s. Send me an email to [email protected] and we will hook you up
Somewhere else I know I asked how you were liking it. I reread your post on page 4 about going from the stage 1 to the stage 2. Idk thst I'd read that before. Our trucks are almost twins then and that makes me more excited to go with the stage 2 kit. I've been on clip 3 since I had the front installed with my ORP springs. Initially I really enjoyed the ride. I still don't mind it exactly but my General Grabbers are trash. They don't balance worth a darn and at times it rides like a covered wagon. Hopeful that an upgrade to the suspension and some new tires brings my joy lof the truck back.I just realized that I never did a latest update..after swapping up from 285/60R20s to 285/65R20s. Both were/are Bridgestone Dueler AT Ascents..which I LOVE!!
I love the look even more now! These are basically 35x11.5s and only added 1lb over the 285/60s.
A great surprise to me was that the swap didn't seem to kill my gearing at all..subjectively it feels somehow better, I think because the speed at each shift points is slightly higher?! I used AlfaOBD to reprogram to 2650mm..and the speedo is spot on to my JBV1 App (V1G2 Radar App).
I generally drive in Tow/Haul Mode and just seem to drive at a speed that matches 2000rpm, which in 7th has increased my speed from ~50mph with 275/55s (3.92 gear), to ~55mph with 285/60s (3.74 gear), to ~60mph with 285/65s (3.62 gear). The truck doesn't seem slower, as it should with lower affective gearing, it seems smoother somehow.
The taller tires slightly improved the ride comfort, but not a ton..possibly the sidewall is increased, but is also stiffer(?). Handling, steering, and braking are unchanged. These 65s seems to roll easier than the 60s for some reason..I expected the opposite. The 65s definitely roll over railroad tracks, ruts, potholes, etc with ease and don't unsettle the suspension in any way..very nice!
I had an alignment done and that settled the suspension at exactly 40.25" at every corner (the specs are shown below..ignore the red caster..tech had the DT plugged in as a DS, so they look off).
I'm leveled lifted at 3.25" F & 1.75" R total lift (tires & suspension)..2.25" F & 0.75" R on just Eibach Stage2.
The Ram rides fantastic now! The other day I had 4 bags of solar salt in the bed, and it still rode fantastic, maybe even slightly better (I've always felt that some weight in the bed really helps these Rams ride smoother).
View attachment 213167View attachment 213168View attachment 213169View attachment 213170
The Clip#3/ORPs weren't too bad, as you've found, but they would sea-saw on some bumps and definitely had a covered wagon ride..at times. The Stage2s completely removed that..very smooth, completely settled on any rough roads now, and very enjoyable ride overall..especially with new tires (although my old ones only had 3000miles on them).Somewhere else I know I asked how you were liking it. I reread your post on page 4 about going from the stage 1 to the stage 2. Idk thst I'd read that before. Our trucks are almost twins then and that makes me more excited to go with the stage 2 kit. I've been on clip 3 since I had the front installed with my ORP springs. Initially I really enjoyed the ride. I still don't mind it exactly but my General Grabbers are trash. They don't balance worth a darn and at times it rides like a covered wagon. Hopeful that an upgrade to the suspension and some new tires brings my joy lof the truck back.
I'm running Eibach Stage2 (non-R rears) and I did actually put the Eibach rear coils in, thinking that I could go without the spacers that I was using with my OEM (non-ORG) Rear springs (which gives 0.75" rear lift)...and it dropped the rear a lot, I was shocked! I already had the fronts lifted 2.2" with the Stage1 struts, so it was a total Carolina Reverse Rake!BTW: today I was looking at old pics (pre 2R install) and just as I suspected the rear is actually lower with the 2R Eibach progressive spring than it was with the OE ORG rear springs. I'm going in for an oil change and rotate/balance soon and I'm thinking about putting the ORG rear springs back on. I think this is not recommended but has anyone done this? Eibach coil overs in front and resovoir shocks in rear with ORG springs instead of Eibach rear springs?
The main point here is with the bed loaded the rear really droops. People use air bags but what about just going back to digressive springs instead of progressive? Or do I have the terms backwards? Either way I'm thinking the bed load should not be such an impact?
Also most guys are leveling these trucks so you are taking out the factory rake which will make the truck sag more!BTW, I forgot to mention..Dave at Eibach told me the Eibach Rear 1" Coil is a 150lb/300lb Dual Rate Spring. He said the OEM was more initial rate, but less secondary rate. He wasn't exactly sure, but thought OEM is around 200-225lb/275lb Dual Rate.
Maybe this helps explain the increased droop & cushier ride of the Eibachs compared to OEMs??
hpbuilt.shop
hpbuilt.shop
Man... NOW you say forum member pricing...More Eibach Stage 2 and 2R kits have hit the shelves for the 19-24s!! Only a couple left of each! Email [email protected] for forum member pricing
Stage 2-
Eibach 19-23 Ram 1500 Rebel Crew Cab Pro-Truck Lift Kit System Coilover Stage 2
Eibach 19-23 Ram 1500 Rebel Crew Cab Pro-Truck Lift Kit System Coilover Stage 2This Part Fits: Year Make Model Submodel 2019-2023 Ram 1500 Big Horn 2019-2023 Ram 1500 Laramie 2019-2021 Ram 1500 Laramie Longhorn 2019-2023 Ram 1500 Limited 2021-2023 Ram 1500 Limited Longhorn 2019-2023 Ram 1500...hpbuilt.shop
Stage 2R-
Eibach 19-23 Ram 1500 Rebel Crew Cab Pro-Truck Lift Kit System Coilover Stage 2R
Height Adjustable Front Coilover and External Reservoir Rear Shocks for Increased Off-Road PerformanceThis Part Fits: Year Make Model Submodel 2019-2023 Ram 1500 Rebelhpbuilt.shop
To be fair..Trevor has frequently stated on the Forum that he gives members discounts for many different performance products, but probably hasn't recently..maybe to not be too pushy. He's a stand up guy for a long time here.Man... NOW you say forum member pricing...
Oh yeah no worries on missing it. I know he posts quite a bit. I bought straight from Eibach, and unfortunately their prices have gone up (whose haven't?). All good, still getting a solid suspension setup.To be fair..Trevor has frequently stated on the Forum that he gives members discounts for many different performance products, but probably hasn't recently..maybe to not be too pushy. He's a stand up guy for a long time here.
His company will cut us deals..or otherwise you have to wait for Holiday Specials from the companies themselves.
Helpfully your post will help others here to be aware of future discounts from them..Hopefully you did get some deal on yours?
ExcellentOh yeah no worries on missing it. I know he posts quite a bit. I bought straight from Eibach, and unfortunately their prices have gone up (whose haven't?). All good, still getting a solid suspension setup.
Appriciate you! Yeah we definitely don't like being pushy and flood the forum with spam!To be fair..Trevor has frequently stated on the Forum that he gives members discounts for many different performance products, but probably hasn't recently..maybe to not be too pushy. He's a stand up guy for a long time here.
