2021QCBH
- Oct 11, 2021
Well, the junky manifolds finally caught up to me. Maybe a new world record for mileage? Just before flipping 110k the passenger manifold cracked right up the middle. Once it was removed you almost couldn’t see the crack.
Removal was straight forward. Wheel off/front fender liner out. Remove heat shield. The exhaust flange bolts are a bit of a pain. I did get the upper one loose and off but ended up cutting the lower with an angle die grinder. All the manifold bolts themselves broke right loose. Had to do some fancy footwork with different length sockets and extensions to get behind the shock tower etc.
Went with the BD replacement unit. Install was easy with the new hardware. The heat shield needs to be re shaped a little bit as it has its own dedicated holes that don’t use the manifold bolts like the factory unit. Manifold itself looks much more beefy and looks like a nicely finished product.
Only issue I had was getting the ball flange seal at the manifold to cat pipe sealed. Small exhaust leak there that took some beating/finesse work to get it sealed up.
I don’t think it’s leaking at all now but the exhaust seems a little louder now under lower rpm and high load (rolling into throttle without downshifting). I’m probably just fixated on it since that’s when the exhaust leak would also surface. Maybe it’s the extra flow they claim? Who knows. Hopefully the drivers side (harder side) holds out for a while.
