Electrical issues after window tint
Emmorel43
Hi everyone—this is my first post, and I really appreciate the input and perspective from other Ram owners.
I’ve been chasing an electrical issue, mainly with exterior lighting (headlights / brake lights / tail lights). I’ve searched online but haven’t found a clear answer for my situation.
What happened
I did a window tint strip on the windshield, and immediately afterward my horn started blaring and the lights were flashing (basically a full electrical freak-out).
What I tried
• Disconnected the battery and left it overnight
• Reconnected the cables the next day
• The truck started normally and the check engine light went off
What’s still wrong
I still have lighting problems—specifically:
• Right rear tail light is out
• Brake lights are out
• Some exterior lights work, but a few don’t
What I’m trying to figure out
Since some lights work and most other systems seem fine, does this point more toward:
• A bad BCM that needs replacement, or
• A ground / low-voltage issue, or
• A fuse / wiring problem?
I’m not very mechanically inclined, but I went ahead and bought a Security Gateway bypass cable. My plan is to test each module and see if anything throws a BCM-related code before I take it to the dealership and potentially spend thousands on a BCM replacement.
I also found a company in Atlanta called UpFix that says they can repair BCMs for my Ram, but I’m worried they’ll get it and tell me there’s nothing wrong with it.
My current plan is to wait for the bypass cable to arrive Friday, run scans/tests, and go from there—but I wanted to ask the group:
Can a BCM that’s had water intrusion actually be repaired, or is it usually a replacement situation?
Most times if fried, needs replaced.
Thanks for the response and a replacing was my initial plan but after researching, I found Upfix who said they can repair a BCM with water intrusion and won’t require any reprogramming. I just wanted to gauge what the group thinks about this or if they’ve heard of such a thing?
How much and do they have a guarantee? Majority I see replace them. If able to fix, would hopefully be better.
$400 to repair and if they deem nothing wrong they charge an inspection fee.
other thing is if they can fix it and you don't have to pay for it to get set up ( programmed) at the dealership.
What happened
What I tried
What’s still wrong
Pull the BCM out, open it up if you can and let it dry out. Could also run the truck with heat to the floor and on high to help dry it without removing. And also get the wire harness dried.
I plan on doing this very thing tomorrow. I’m gong to clean the male/female connections with electronic contact cleaner. If this doesn’t work, to the BCM repair shop I go.
These are codes the Body module is throwing.
BODY CONTROLLER
#B1208-11
anti-theft indicator - circuit short to ground
anti-theft indicator-circuit short to ground
stored
#B2143-11
ugdo enable control - circuit short to ground
ugdo enable control-circuit short to ground
stored
#B170B-15
right reverse lamp control - circuit short to battery or open
right reverse lamp control-circuit short to battery or open
stored
#B21F9-13
exterior lighting power supply input 2 - circuit open
exterior lighting power supply input 2-circuit open
stored
#B168E-2A
front fog lamp switch - stuck
front fog lamp switch-stuck
stored
#B16D7-11
left taillamp 1 control - circuit short to ground
left taillamp 1 control-circuit short to ground
active
#B162E-11
right low beam light or high-low beam supply - circuit short to ground
right low beam power supply - circuit short to ground
right high low beam supply - circuit short to ground
active
#B16AF-11
stop_parking light right - circuit short to ground
left stop lamp control - circuit short to ground
left stop lamp control-circuit short to ground
active
#B16B7-11
center stop lamp control - circuit short to ground
center stop lamp control-circuit short to ground
active
#B177B-11
right front lamp diagnostic line - circuit short to ground
right front lamp diagnostic line-circuit short to ground
stored
#B1646-11
rear right turn lamp control - circuit short to ground
rear right turn lamp control-circuit short to ground
active
#B1792-11
left rear lamp diagnostic line - circuit short to ground
left rear lamp diagnostic line-circuit short to ground
stored
#B177A-11
left front lamp diagnostic line - circuit short to ground
left front lamp diagnostic line-circuit short to ground
stored
#U0002-00
can c1 bus off performance - nessuna informazione a supporto
can c1 bus off performance - no subtype information
can c bus off performance-
stored
#U1433-23
implausible ignition switch status message received - signal stuck low
implausible ignition switch status message received-signal stuck low
stored
#U1045-00
lin 3 bus-
stored
#B165C-11
right signature lamp control - circuit short to ground
right signature lamp control-circuit short to ground
stored
Looking forward to your results. Definitely seems like a water intrusion with what those codes tell you. Only thing in my mind would be if the water shorted out anything internally. If you get it dried out hopefully you will have joy again.
I'm getting my new windshield tinted right now. Hopefully, I have no issues... 🤞
I may be screwed since this happened a week ago. Plus the tint guy isn’t insured but said he’l make me whole. Fingers crossed
As long as the shop is aware of the potential issue and takes steps to prevent it, you should be okay. I know a few local shops that won't touch Ram windshields because of the risk of damaging the BCM.
Yes, I talked to the installer about it ahead of time and he was well aware o0f it. In fact, he was putting tint on a Rebel in his shop when I dropped mine off.
