Wicked Bumpers
Meltedchip
I ordered front and rear bumpers from Ben at Wicked Bumpers in Nebraska for my 2023 1500.
Ben was very helpful. He took the time to answer all my questions and kept me updated during the build.
When they arrived they were bare steel so I had to have them powder coated.
Install was simple, all hardware (nuts, bolts, and washers) were included.
The only extra I needed were the parking sensor grommets. They were $15 from the Ram dealer for each set.
Build quality and fit are great.
I like the new look. They are definitely more robust than the factory bumpers.
If your looking for a different bumper consider Wicked Bumpers.
Looks Great!! Do you have a part# for each set?
Contact Wicked. He will make what you want.
I asked for the square bar on the front. He said it might interfere with the front camera but it is very minimal. I think he has a round bar option too.
He cut the flush Morimoto pattern I asked for; which fit great.
He sent extra supports that connected to the bumpers to the factory tow hook mounts.
I also asked him to cut holes in the rear bumper for the factory license plate lights. I had to do a little filing to the plastic light housing to make it fit.
He makes a different height bar to clear the camera. Square bar just looks better. Round bar on an otherwise square/angled flat surface bumper just doesn't look right. Can even get it wirhout the bull bar.
you are probably the first to get one with factory license plate lights. I have the second rear bumoer he made. Would have been the first one, But I didn't want the cutouts in corners for steps because I already had the factory retractable bed step. But my truck was used for fit and finish for both front and rear bumpers. My front bumper is the very first 5rh gen one he made.
I've already got other bumpers, but wasn't sure if I needed the sensor grommets, so was looking for a part# in case. I haven't installed them yet, probably the next month.
THen you should reach out to the company that made the bumpers. They may use a different style grommet.
I was away from internet for a few days.
As HSKR R/T said, these may not be the ones you need with a different bumper.
Yep, first one he did with factory license plate lights.
He said he had only made a handful of rear Ram bumpers.
