question about the ZF 8 speed transmission..
RAMTEXAS
Texas
can the ZF 8 speed transmission shifting memory be reset?
i know on most newer vehicles it is possible but i wasn't too sure about the ZF 8 speed.
Quick Google search came up with some options. I would start with there.
Try power on without foot on brake, then slowly cycle the pedal from idle to wide open a few times.
That's a throttle relearn, not transmission
I had a ZF8 in my SQ5 and with the 034 tuner the transmission could be 'reset' and there were a number of parameters that could be adjusted, like how hard it shifted, RPM shift points, and removing the 200 lifetime launches, etc. What I don't know is how much of that tunability is tied to the ZF8 vs. VAG-specific TCU's. So if there is a way ... it'll likely be through something like the AlfaOBD or what the dealership has access to.
damn i didn't know audi used the ZF transmissions lol
It’s currently the most reliable trans you can have in a vehicle right. BMW M division even swapped to it from their dual clutch for better reliability and lost next to zero performance.
If you have AlfaOBD or JScan, you can reset the transmission adaptives and perform a quick relearn. Or you can adapt each clutch via the adaptation procedure.
Sent from my SM-S928U using Tapatalk
My understanding is...
*Throttle Reset:
Power button to ON (but don't start engine), Slowly press Throttle to floor, then Slowly release Throttle from floor, then Power button cycled OFF, done.
*Transmission Reset:
Power button to ON (but don't start engine), Slowly press Throttle to floor, HOLD DOWN for 20-30 seconds, then Slowly release Throttle from floor, then Power button cycled OFF, done.
(I'm curious if the Trans Reset also does a Throttle Rest by Default??)
ZF 8speed swaps are the latest, greatest muscle car mods now days!
You can actually buy NA-LS/LS Strokers/SC'd-LS with ZF 8spd combo packages from a number of companies now.
Hot Rodders love them for the 4.71 first gear and double overdrive..plus, they are surprisingly easy to setup! A number of companies are making stand alone TCMs to use with salvaged ZFs.
I'm not a fan of Automatic transactions muscle cars, but if the right one came along..now I might bite, and do a ZF swap.
