Does your driver's side mirror whistle?
tinfoil_hat
There's a TSB for that. The whistling sound apparently comes from the temperature sensor door.
Most people seem to complain of whistling when driving above 60mph. Mine does it at 45mph exactly. i have tried reaching out of the window to locate the source of the noise and it stops with my finger over a litle indentation on the bottom.
Well, looks like there is an updated cover for the sensor. I'll post the p/n if I can find one. Otherwise, I'll bring it up when (if ever) I get the trailer controller recall done.
Nice, maybe I can get mine fixed properly now. I got the infamous, could not duplicate when I asked them to check it….
I cut out a small horseshoe like shape piece from the hook side of some black industrial velcro. Matched it up pretty perfectly to the radius around the temp sensor, and it’s on the tail end side. Honestly can’t even tell its there, its been on close to a year, and it fixed the whistle. But I’m looking forward to getting an actual replacement part.
I think I could have chamfered the edge is the same area and accomplished the same thing. I didn’t really want to go carving on a new truck… Hopefully I can have them get me the updated part in order at my next oil change.
My 2019 RAM 1500 howls apparently off the passenger side in heavy winds (like driving across Wyoming). Not steady but when we hit gusts and is very loud. Passengers get kind of scared. I think it may be that the door seal opens slightly. Wish there was a fix.
One of my previous 5th gens did this. I "fixed" it by adding some RTV around the temp sensor (leaving the tip exposed) to seal it off.
My current 5th gen is the same, but not really a howl, and doesn't take much wind to cause it... Just a slightly annoying whistle. Tried taping off just about every seam over there to isolate but never figured it out.
