Best Cabin Air Filter?
Starkhaus
I wanted to get everyone’s opinions on what you think is the best cabin air filter.
My main concern is if it’s possible to eliminate outside odors from making it in the cabin while driving. I’ve mainly noticed when around diesel trucks it’s almost unbearable and I have to turn the air off seems like almost no filtration from my filter. Also don’t want to choke up the airflow either with something thick
Best wishes on your choice
Keep us posted and add your opinion decision to the above thread
Any cabin filter that will remove odor (probably not any) would be too restrictive. Even a standard cabin filter that has carbon filtration is too restrictive, not enough airflow for the AC.
Get one that’s not too thick, it will impede air flow. I use this one.
EPAuto CP671 (CF11671) Replacement for Mazda CX-7 / RAM 1500,2500,3500,4500,5500 Cabin Air Filter includes Activated Carbon https://a.co/d/bUdxLLB
I had replaced my cabin filter with a Bosch Alergy one, to help my wife out, but the flow was terrible. I replaced with the mopar one, and the blower level 7 with bosch was the level 4 with the mopar cabin filter. I guess it is the Mopar from now on. I was pulling my hair out trying to figure out what I did.
x2 for K&N - installed one in my '25 Laramie along with their replacement under-hood air cleaner.
K&N, though I didn't notice any improvement in air flow, but even if the same flow, the fact it's cheaper than the factory and can be reused over and over again, well reviewed, it's pretty much a no brainer.
After a year and a half (oops) I changed out the factory cabin filter to a cheap “carbon” filter on Amazon. After having it in a few weeks it felt like the airflow dropped, so while the truck was running I slid the filter out and air flow literally doubled! I was thinking of just getting a plain white filter but instead I just ordered a K&N. A little more money but probably worth it. It doesn’t look nearly as restrictive.
i use a HEPA one and replace every year or every half year, depending on how much chasing I do on dirt.
Been through some triple digit days and never had an issue. I set my AC at 68F year round, and only set it to max when i first get in the truck.
the Bosch HEPA one been working fine for me.
Nobody is getting HEPA in a filter that size and blower this small. It's all marketing hype.
So just get whatever makes you feel good for dollars vs filter life.
you are right.
i don't really feel any difference, other than I do smell bad air from outside less.
