Odin - Build Thread
TheHops
Hey all! I just picked up my 2026 Rebel about a week ago. I live in MS, and flew out to AZ to close the deal. We made a nearly 3,000 mile road trip out of it and hit 7 national parks between the dealership and home. Hell of a way to break in a new truck. Adventures like this are just the start!
My plan for this build is to maintain comfort, economy, and drivability to the maximum extent possible while introducing some additional functionality and performance from the aftermarket. Unlike my last vehicle (a heavily modified Gladiator Rubicon that I absolutely love...not looking forward to selling it, but I can't have two vehicles), this is going to be a family truck first and an adventure vehicle second.
Equipment/options:
  • Granite Crystal Metallic
  • Luxury Leather-Trimmed Bucket Seats
  • Technology Group
  • Advanced Safety Group II
  • Bed Utility Group
  • Level 2 Equipment Group
  • Panoramic Sunroof
  • Multi-Function Tailgate
  • 33-Gallon Tank
  • Engine Block Heater
  • Decal Delete
A few future plans in no particular order:
  • Suspension upgrade
  • Camper shell
  • Cargo glide
  • Sliders/steps
  • Additional lighting
  • Winch mount
  • Onboard air
I look forward to chatting with y'all and sharing my adventures and progress on the truck! More to come soon.
1000016641.jpg1000016658.jpg1000016674.jpg1000016802.jpg1000016893.jpg1000016929.jpg1000016931.jpg1000016974.jpg1000016945.jpg
I've done a few small things to the truck over the past few days--removing the factory rear underseat storage caddy and installing a legitimate box (DU-HA), adding some (very close match) granite crystal overlay/inlay decals to the front and rear Ram badges, mud flaps (RokBlokz--great quality) install, and now a lighting upgrade. The only one I really felt was worth documenting were the lights.
I've seen several videos that, in my opinion, went far more in depth than this project required, so I'm mainly here to document it and to express my satisfaction with it. It's unbelievable to me that trucks this expensive still come with dim halogen bulbs, but it is what it is. I went with these bulbs from Lasfit, as I saw them recommended across multiple sources. Of note, 4 red bulbs are required for the taillights, (pictured below in the center, part number L2-7443R) not 2 as pictured. My other shipment arrived an hour or so after I took this, so I didn't get the other box in the shot.
I'm impressed with the quality and feel of the bulbs. I will say, I believe Lasfit markets themselves as an American brand (and I've seen them stated as such in various install videos), but their bulbs are clearly labeled as being made in China. Just something to note, in case that's a make or break kind of thing for you. For the taillights (2 red bulbs and 1 white bulb per side), it took less than 5 minutes per side. Nothing to go in-depth on here--simply remove 2 torx head screws and 2 plastic rivets, then pull the housing to the rear of the truck to release. The results, even in daylight, were immediately apparent.
Halogen Bulbs:
LED Bulbs:
They're much brighter and provide a much deeper red. The reverse lights are also much brighter and are a purer white, though I didn't get a picture of this. Now, for the front turn signal upgrade: This warrants some talking about.
I commend Ram for making the bulbs easier to grab with the paddle-type housings the bulbs click into, but they can still be difficult to reach. I haven't seen anyone else mention this, but my advice is to grab a 19mm socket or box wrench. This size fits nicely over the paddle that you need to twist to remove the bulbs and allows you to generate torque in that tiny space. My hands were too big, and the bulbs were too tight, to do it by hand. A socket made it a breeze, and both sides only took about 10 minutes total once I figured that out. For those that haven't seen it, the paddle in question is pictured below--the textured piece at the bottom-center of the picture. This point of view is standing in front of the passenger headlight and looking down into the engine bay. You need to turn that paddle counterclockwise and back the bulb out.
Again, great results here. The amber is deeper and much brighter, and being switchbacks, they also stay on as white lights while running. They almost appear to be an extension of the white headlights.
Halogen Bulb:
LED Bulb:
Quite a difference overall! For a fairly inexpensive mod, I'm very impressed with the results. Definitely recommended!
On my end, it'll likely mostly be smaller projects like this until time and budget free up in the spring. I'm planning on bringing a couple of things over to the Ram from my Jeep, though. We'll see how that goes. Stay tuned!
I did a quick install today of my ICS dash mount system. Of note, they only advertise this system as fitting the 12" radio. I took a chance and ordered it on their Black Friday sale and it fit perfectly with my 14" radio. Install took less than 5 minutes: Remove the rubberized tray up top, remove two screws from the dash, insert the base of the ICS mount, reinstall the 2 screws, then use 4 screws to attach the ICS top plate to the ICS base plate. Not pictured are three AMPS 20mm ball mounts and three 67 designs arms that I'll use to mount my phone and two other accessories.
Very impressed with the quality. It seems heavy duty and the powder coat is flawless. Always happy to support a solid American company. 🇺🇸
I picked up a few other things for Black Friday that I'm hoping to get on the truck within the next few weeks! Looking forward to continuing the build.
I took some time today to get my VICE Design amber grille lights installed. The install itself was straightforward and took maybe 15 minutes. Dropping one of the lights into the abyss of the engine bay, however, added about an hour and a half and an eventual full front grille teardown to the effort. I do not recommend doing that...
Anyway: Very pleased with the quality of the lights and the kit itself! It has a very custom feel, and the lights crisply snap into place in the grille. I was happy to see that they replaced the wire "hub" that I've seen in some install videos with a much simpler 4-way harness. To be honest, I have no idea why they didn't do that in the first place. I did forego the plastic split loom that they provided for my own woven 1/4" (for the main harness) and 1/8" (for the individual positive and negative wires) loom to offer a bit more protection. Overall, it's a fantastic bit of kit and provides some added visibility, which I'm a big fan of.
I'll be doing some additional lighting/wiring work over the next couple of weeks.
Side note: Also pictured for the first time (but installed a couple weeks ago) are the granite crystal metallic-ish front decal overlays. They match the paint really well and add a nice, subtle pop to the front and rear decals.
Integral locking bedside panels for Milwaukee Packout boxes are on! Easy install overall. The hardest part was getting the bolts to thread into the track anchors. They like to pop just far enough in that the threads on the bolts can't quite bite. A shallow socket would have made short work of the job, but I didn't have any. Instead, I used a plastic trim tool behind the anchors to keep them far enough out so the bolts would grab. All in all, about a 15 minute project from assembly to install if you're taking your time.
20251222_133640.jpg20251222_133646.jpg20251222_133728.jpg20251222_133733.jpg20251222_133746.jpg20251222_133743.jpg
Overall, I'm very pleased with the quality. They're heavy duty. The customer service was great, too. I was short some hardware, and the company got back to me very quickly and rushed what I needed. For reference, I had a full BuiltRight setup in my last rig. Those are great products, but I'm fairly sure their prices went up and I couldn't justify it this time around. For the price and precise function (all I really needed to mount was Milwaukee Packout boxes) it was a no brainer.
I won't be mounting the boxes full time until I eventually get a bed cover (leaning towards a camper shell) but the panels are on there now in case I need them.
Merry Christmas, y'all!
I managed to get my light bar/grille setup knocked out over the past couple of days. I'm trying to take advantage of the holiday break from work. I used a SDHQ hidden light bar mount and 4x Baja Designs OnX6+ 10" bars. When I get the time, I'll be posting some install videos that will have more impressions, but the short and sweet is the SDHQ product itself is ok, but the instructions are terrible and do not appear to apply to a 2026 (Rebel) model even though they are advertised as 2019+.
The project was fairly involved, but not overly difficult4. First I built custom harnesses for the BD lights. I snipped the standard 3-prong ends and spliced the paired bars together into a 4-prong weatherpack connector--2 positive and 2 negative wires for each set of light bars. I don't intend to use the bars' low/hi function, so eliminating the third wire on each bar cleaned it up a little bit. I ran a 6 inch 12 gauge extension from each 4-prong weatherpack before splicing the 2 positives and 2 negatives together. I finished it off with a 6 ft 10 gauge extension up into the engine compartment (though it looks like I'll only need about 4 ft, so I'll be trimming).
I'll spare you guys the nitty gritty (again, until I put together my video and install guide) but the bottom line is that I was able to stuff 40 inches worth of light bar behind the grille. Primary notes/words of caution:
  • Again, SDHQ's instructions are, in my opinion, pretty bad. Even if they did work for the 2026, there are some pictures missing that I feel should have been included, such as more detail on bracket orientation and more shots of the active grille shutter motor.
    • For my 2026: Some bolt/clip removals were incorrect, wrong reservoirs were (temporarily) recommended for relocation, and worst of all their light bar mounting locations were wrong. Their lower recommended perch but my light bars smack behind grille trim, and so I had to uninstall and reinstall 2 of the 4 bars. Thankfully, I was able to find good spots (which were recommended for the Laramie trim, I believe) or I would have been asking for my money back.
    • The entire active grille shutter system (aside from the motor) must be deleted. The motor itself is retained and mounted to one of the included brackets to avoid a CEL, but the grille is now completely open.
  • BD OnX6 bars can, apparently (to my surprise), ground via mounting hardware. The SDHQ brackets also ground to the frame via their mounting bolts. Depending on your setup, this may mean that your light attempts to run full time. I'll be wiring up to an sPOD which I believe completely isolates each circuit, so I don't think it will cause any issues. We'll see.
Here's what we've got:
SDHQ-recommended incorrect (lower) bar location
Actual 2026 Rebel required location
Wire connections/exit
Finished
All lights are fairly unobstructed. The lower 1/8th or so of the amber (driving/combo) bars are partially blocked by grille trim, but it's not nearly enough to cause any issues. I tested them and there is still *plenty* of light output. The top white (spot) lights have about 1/2 inch of clearance below the "RAM" emblem. Overall, despite the hiccups/incompatibilities/AGS system removal (which I could take or leave anyway), it's exactly the OEM+ type of look that I was going for. Can't wait to test it out on some back roads.
I was able to complete the wiring on the grille bars this past week. The parts involved were an sPOD Bantam X, HD controller, an sPOD bracket by NH Overland, and a center console insert by SKT Customs.
The NH Overland bracket, while good quality, did not work as advertised (at least, I couldn't figure it out) with my 2026. It was supposed to mount where the fuse box meets the core support behind the driver side headlight, but I couldn't seem to make it fit in any orientation. Fortunately, I was able to come up with another solution by replacing a bolt near the driver side hood strut with a long bolt, and a 3/4" aluminum spacer. This standoff allows the sPOD to clear the hood strut and the (closed) hood by about 1/4". I think I actually prefer this position, so it worked out. Additionally, I cut out the 100a fuse that came on the sPOD harness and swapped in a 100a breaker so I can isolate the system at will. I just drilled two small holes into the NH Overland bracket to mount it.
Despite all of the labels on the control panel (I carried it over from a previous rig) only circuits 1 (amber grille bars) and 2 (white grille bars) are functional. I do plan on running some additional circuits down the road, such as a compressor (tentatively planning on using a SDHQ rear storage cubby mounting bracket), winch (relay/isolation), and some trailer/camp lighting, but those will likely be distant future projects.
Not so much a mod, but I figured it was worth sharing. If you use the top dash 12v plug at all and want to take it from constant hot to ignition hot, here's a quick how-to I came across. TL;DW(atch), pull Fuse 54 (20a) from beneath the steering wheel and move it one slot to the right from slot A to slot B.
This will be helpful in the future when I'm running accessory devices while out camping and don't want them constantly draining the battery.
After months of waiting, I finally received and installed my S&B CAI. This thing is a beast. Great build quality, not-so-great packaging, as everything was essentially loose in the box without any type of padding (aside from the filter itself). Thankfully it feels pretty bombproof, so not a huge deal.
Very easy install overall. Initial impressions are that I can't really tell much difference in terms of sound, but I do feel maybe the *slightest* improvement in response time/engine pickup. The Hurricane seems to be a very quiet engine, but other vehicles I've put CAIs in have had easily noticeable changes in intake noise, so I'm a bit disappointed on that front here. In terms of performance, I know that in general CAIs aren't gamechangers, but I eventually do plan do add an exhaust and a tuner, so I wanted to get a more freely flowing filter in sooner rather than later. Overall I'm not mad about the purchase, but I probably wouldn't recommend it unless you had some additional performance mods planned or already installed to complement it.
EDIT: After driving the truck a bit more, I can say that I actually do pick up on a slight change in sound. There's a noticeably deeper (but still subtle) intake growl when the engine is under load. Additionally, a couple days after (correct) installation, I did get a check engine light and code P0174 (Engine bank 2 running too lean). I cleared the code and haven't had any issues since, but I may bring it up to S&B just so they're aware. I assume that means this intake does in fact increase airflow. Hopefully the computer is up to the task of keeping the AFR in tolerances.
Big mod! I found a camper shell for sale that had just about everything I wanted. It was worth the 10 hour round trip.
Leer 100XR with windoors, carpeted headliner, and roof rails. It also locks/unlocks off of the key fob. I plan on adding some additional sealing and wiring it up within the next week or two. For now, I'm just happy to have another cap. For me, you can't beat the functionality of one.
More pictures/details to come as I get to work on the bed area. Now that I have a cap, I'll be able to add my toolboxes and a couple other things.
View attachment 211846View attachment 211847
Any cels since?
Any cels since?
I just edited my post yesterday. I actually did pick up a CEL (P0174) for running lean on bank 2. I had an unrelated auto stop/start CEL, so I didn't even notice that I had a new CEL until 6 days after I installed the intake. I'm not sure when exactly the code popped up, though I imagine it was very soon after install. I didn't notice the truck (negatively) running any differently, so I assume the computer was able to accommodate the increased airflow. I cleared the code on Feb 12th and haven't had any issues since daily driving it.
