2025 Rebel Extended Fender Flares
Johnsamir
After quite a bit of searching I found that husky liner makes an extended flares that work with the rebel. Got one side installed today and I am very pleased with how they turned out.
But I see a couple of small gaps towards the lower part near the side step. Any ideas on how to make it flush?
Not sure if I should use some adhesive or what? Attaching some photos below.
Installation utilized existing screws and fender holes.
Sometimes they fix themselves. Sort of like some cell phone screen protectors. Bubbles just go away.
Does it say anything in the instructions about a break-in? Might wait a bit before messing with them.
I've heated up some abs stuff and reshaped it. Worked on vinyl siding too. Have to be careful though. You usually don't realize you're overheating it until it's too late.
P.S.
Looks good on the truck. I never cared much for flares, but they look good with the Ram body style. They came on mine, and I probably wouldn't have put them on. Seeing yours might have changed my mind. It works. Enhances the look.
P.S.
Thank you, yeah I’m not a big fan of the flares with screw holes on them etc. these just look sick in person too!
Thanks for the info
are these only for the front?
can
can you tell me where you found these?
Did you remove the existing fender flares, or just these on top?
