Power folding mirrors?
pizza_pablo
2022 Ram 1500 Bighorn quad cab 6.4.
What are my options for having power folding mirrors?
I'm only 5'8" but have to duck my shoulder under the mirror when exiting in the garage where I try to keep her.
I could be wrong but I believe the only way to do it is with Tazer. There is no factory setting for it and I have alpha OBD and I don’t think that will do it. I think it has to be a live setting that Tazer can do because it stays plugged in all the time. Also I would actually advise against it because I think the mirrors have plastic gears that wear out quickly if they move all the time
Need the proper mirrors, door modules, door panel with switch to start. Then AlphaOBD, Jscan, or Tazer (for auto fold). Security bypass and OBD scanner to use with AlphaOBD/Jscan.
This is the answer. To put it another way:
1. To get folding mirrors, you need the parts and programming listed using AlfaOBD or JScan
2. To get auto-fold, you would need Tazer as the door modules don't support auto-fold
It is 100% possible with Alfaobd. But as others said, you need the correct mirrors, door modules and window switch panel. Then enable the setting with Alfa. I did this mod on my dads 2023 truck when he had it.
Thanks!
I have the Alfaobd program and equipment.
What was the cost of the mirror parts needed and how long ago did you do it?
