hurricane or 5.7/6.4 hemi
2026 ram trucks come with 10 year 100K mile powertrain warranty regardless of engine choice.. that should be a piece of mind for the long term buyers
I bought my '23 new right after the '25 came out. Didn't want to take a chance on the '25. If it had the same 10 year/100K, I might have bought the '25. Especially since I drive less than 10K miles / year. I'm still not going to trust it until many people are reaching 100K. Though with that warranty, you could get major repairs fixed and trade it in if it ends up in service too often.
I've had mine almost 2 years, no major issues. The battery was replaced under warranty. Had 2 cylinder misfires, also replaced under warranty.
you can always reach out to @Zach@granger. i hear they have OEM warranties pretty cheap sometimes.
There are a lot of Hurricanes over 100K miles. Theyve been used in the Grand Wagoneer for 3-4 years
When I was shopping for a truck I concluded that there is no "forever" vehicle.
Pretty much anything made after 2015 is too complex for me to maintain and repair myself. That means paying ~$200/hr for someone else to do it, and that's a non-starter. Then I'd rather have something new enough to be under a warranty of some sort.
The result of that is to not care so much about engines lasting beyond 100k, and just avoid the worst of the bunch (like the GM v8's, any Toyota turbo, any Nissan, etc). From what I can tell, there are no signficant differences in reliability between the Hemi (simple, but eTorque crap) and the Hurricane (just not simple, but no real problems).
I had a ram 1500 big horn 2019 with a hemi. I have a 2026 Laramie with the SO hurricane. I’d buy the hurricane over and over. Power is smooth, linear, and man it hauls ***. I use 93 in it.
Not sure why people think the Hurricane is this crazy complicated engine with lots of moving parts. Comparatively, it's far less complicated than the current He.i with e-torque .
Only the HO requires premium
As was pointed out to me earlier today, and after a little research was verified, the HO recommends premium fuel, but it’s not required…
With 100k mile warranty on new Rams now...I'd get the Hurricane. I love the Hemi sound and slightly quicker response. But when turbos spool up....its not like anything you've felt in a NA engine. I say that after owning a F150 2.7 Ecoboost, and that wasn't even a I6.
The 2.7 Ecoboost is rated 100hp less than the Hurricane, so it isn't going to be close. I put a 5-Star 93 octane custom tune in my 2022 F-150 2.7 and it made 370rwhp and 440rwtq SAE. That tuned motor was a beast! Now it was the equal of Hurricane, maybe slightly quicker due to its lighter weight. I'd take the Hurricane over the 2.7l any day of the week and even over the 3.5 Ecoboost. The inline 6 just has such linear, strong torque performance, so impressive.
You're kidding, right? TWO turbos, oil feed lines, direct injection, dual overhead camshafts with twin timing actuators, parts you can't even access because they are mashed against the firewall, etc. etc. 14 hours to do a simple water pump because of the complexity. I've heard 21 hours on the timing system because of the complexity.
In what galaxy is this simpler than a basic pushrod V8?
2 turbos and oil feeds aren't a big deal and they're easily accessible. Dual overhead cams, still not a big deal; variable timing components, HEMI has the same. 1/3 of HEMI sits under the cowl and up against the firewall. I don't believe 14 hours for a water pump at all or 21 hours for the timing system, it's a straight 6 so it's not going to be crazy complex like a V6/8 would be.
I doubt either is that much more difficult to work om vs the other or more complex but the reason the HEMI is outdated and behind every other Ford and GM V8 is that same simplistic refuse to modernize basic pushrod V8. GM has had the Gen 2,3 and 4 LS and Gen 1, 2, 3, 4 and 5 LT's and have now Gen 6 while the HEMI is still on gen 2
Thats exactly what I'm saying...after owning a 2.7 ecoboost, I could only imagine how great and monsterous the Hurricane is. The only advantage the Ford has is being lighter weight from the aluminum body.
I did ;-) But to the fair, I chose the RAM over Ford due to not liking the Ford's ride quality.
On Youtube, TFL did some heavy towing tests with the 3.5L EB and found that when under load it retards timing, generates a lot of heat, uses a lot of fuel, and de-rates itself. The Hurricane did not do that; something about the very high pressure fuel pump helps with cooling so it doesn't de-rate. It would be interesting to see if higher ethanol blends improve that, like it does for other DI engines I've used (but would likely need a tune).
I'm guessing at elevation all the turbo motors are going to have huge advantages over the NA motors as well; that's certainly a factor for any use case.
I'm not kidding. Direct injection isn't any more complicated than MPFI on the Hemi. . Turbos aren't complicated if you understand them. DOHC isn't that bad.
And yes, I have owned, and modified, a single turbo, DOHC Dodge before. I was anxious about tearing into that engine, until I did and realized it wasn't any more difficult than other engines I had worked on.
I purchased our 1st RAM with the intention of driving it and not working on it. The purpose of selecting a RAM was because GM, Toyota, and Ford, aren't really tending to the design mess (main bearings, lifters, trans, etc.) they've created over the past 5 years. If you compare the stats alone, it's a no brainer, the Hurricane is a better performing engine. For sound, I have a radio! I understand the loyalty and long-standing history of a Hemi, which drives people to select that engine. I'll drive mine until such time the warranty expires.
