5W30
Just bad info all around, other than recommending UOA.
Someone doesn't know how engines or oil work. Chrysler themselves recommend all the oil weights I mentioned above in this engine. If it was legit bad info, you would have provided reasons why.
Watch the video I posted.
Switched to 5W30… the W30 oil raised the warm engine idle oil pressure by about 15%…from 28-29 psi to 33-34 psi
I use 5/30wt. Over 40 years working on cars. Someone mentioned engineers, they are not in control of what oil to use. The government is. The government has fuel efficient requirements the auto manufacturers have to meet . I order to get as close to those requirements they have went to lighter weight oils . So engineers do the best they can with the rules they have to work with. This is my opinion, the lighter weight oils will not protect the timing chain over a long period of time, and possibly the lifters are developing issues because of the lighter weight oils. I think bearing and ring life has proved to be good. My biggest concern is the timing chain. Small pins and chain tensioners just stress the chain to much over the long haul with the light oil.
It's odd you even bring up timing chain as that was an issue on the early Gen 3 Hemis(when 5w-30 was recommended )but has not been a significant issue with the lighter oils.
The quality of the oil you use determines how well it will protect your engine more so than the viscosity index of it.
Quality does matter as well as the shear strength under load. The chain pins are small and the surface they ride on is small. This is where the pressure is the highest and need all the protection that can be achieved. As for early hemi’s , I am not directly speaking brand specific. I have a 05 Durango with 200,000 miles laying in the weeds. Never lost the timing chain,but lost oil pressure and knocking. Never dug into it enough to know if it’s cam lifter or rod knocking issue. 5/20 was used in it. I have Subaru 133,000 miles that has had Castrol full synthetic 5/20 used in it since new. Stretched timing chain issues. Recently changed to 5/30.
Oil isn't going to cause the timing chain to stretch. And there isn't any significant difference in sheer strength from a modern 20 weight to a 30 weight. In fact, a 5w-30 will sheer easier than a 5w-20. I'm guessing you didn't watch the video I posted either.
No I didn’t watch video. The lack of oil (proper lubrication)will cause timing chain stretch,and timing gear wear. Combine that with the vvt controlled by cam phasers, it doesn’t take much wear and a CEL will be tripped because a cam will be lagging behind what the ECM thinks it should be in modern engines. The ecm watches the coralation between the cam (cams)and the crankshaft.about 1-1/2 degrees difference is all it takes to trip the CEL.As I said I been turning wrenches for over 40 years and have learned what works for me the long haul and what doesn’t. How about you, do you work as a mechanic? Or just watch videos and play on the internet.
Nope, I don't have a clue about anything mechanical or building engines for performance.
While I'm not an automotive mechanic by trade, I have been turning wrenches since I was in elementary school helping my dad in the garage. Did 20 years in the Navy as a Aviation Electronics Technician, still work on military aircraft but now as a civilian contractor. I also do my own tuning on my vehicles.
That’s great, I am on my 2nd hemi. 2021 ram. 1st one is a 2005 Durango. Right at 200,000 miles. Lost oil pressure and has a knock. Never tried to figure out where the knock is coming from. Does sound like it is up high in the engine,but with no oil pressure,probably not good. I used 5/20 in it. The rest of the vehicle is not in great shape so figured why bother.
Not sure if you are being sarcastic or really only know the tuning side of engine performance. Either way you have some idea of what’s going on. There are to many keyboard warriors that talk a big tail and when it come down to it,have never had a wrench in there hand. On another form for a different brand, I ask a question. Had over 60 replies ,mostly from the same 2 people. Come to find out neither had a clue how to fix a car. I was not familiar with the brand ,had a good idea what the problem was. I took it to dealer for diagnosis only. They wanted to pull the engine to fix it. I said ,we are not doing that and brought it home. After some research I used my scanner to reset something’s, spent $10. On some parts and it’s good. That’s why I question post.
100% sarcasm in first sentence. I only mentioned the tuning part to show that I'm much more than just a wrench turner, and so far more than just replacing parts. I've done all the work to the two tone Dakota in the pictures. Only thing I didn't do my self is build the transmission, machine the block, and balance the rotating assembly. The engine pics are a 410 stroker. I'm currently in the middle of doing a 6.4 Hemi swap though.
I feel better about your response in the previous post. At least I am talking to someone with hands on experience and knowledge.. I did take time yesterday evening to watch the video. Mostly what I expected to see. A few key take aways from that video. He claims the 5w20 will protect as well as the 5w30 as long as the oil does not break down. Also if I remember correctly,he said once the 5w20 starts breaking down it goes fast and the 5w30 does not break down as fast. For me ,that’s a problem with the 5w20. And possibly the issues I have seen with timing chain wear. For the most part ,I am not concerned about bearing wear. The surface is large enough that the oil will float the shafts and rods. It’s the small parts under pressure that I have seen the problem, such as timing chain and lifters.
Another key take away from the video goes back to what I originally said. Some engines are held to 0w20,5w20 and the like,because of CAFE requirements by our government but in other countries the recommendation is 5w30. So anther way of saying that is the engineers would rather use 5w30 but are not allowed to because of regulations. I have been around long enough to remember when NACAR pit crews would put a light weight oil in the engines to qualify and then change the oil to something heavier for the race. That’s because the engines wouldn’t finish the race with the light weight oil. NASCAR put a stop to that by requiring that what oil was in the car when qualifying had to be in the car to race.
That's one way to take the video. About he also said there was a higher number of 5w-30 samples that had sheared than there were 5w-20 samples. And that because of the amount of viscosity modifiers the 5w-30 was more likely to break down a shear.
Comparing racing oils used by NASCAR teams to the stuff your average consumer buys from the store is a big stretch. All high dollar racing teams, no matter which form, use custom blends nobody else has access to and they blend them to achieve specific results. They don't use the same oil at Talladega as they use at Martinsville. those are two completely different operating environments that require different additives and viscosities. They are also tearing down the engines after every race inspecting and rebuilding. Then adjusting the oil blends, if needed, to correct any issues they may have found.
This is why, even the off the shelf "racing" oils, available to the average racer, have far shorter drain interval recommendations. They aren't designed for long term use. Most don't recommend more than 2-3000 mile drain intervals. Modern synthetic oils for daily drivers can go 10k+ is properly maintained engines, and still have adequate protection.
I'm running 5w-30 Pennzoil Platinum high mileage oil in my 99 Dakota because it has 195k miles on factory long block. I'd run a 5w-40 high mileage if I could find it. I'm also do 5k drain intervals, but may shorten that based on the next UOA. The last one showed higher than average wear metals at 3k miles. I still stretched it to 5k. It's due for an Oil change. Will submit another sample at 3k miles again.
I agree that comparing racing oils is a stretch,but the basic idea is the same. We all have the brands we like and use them . Oil manufacturers are constantly trying to improve there oils. I have used Pennzoil in the past but noticed some sludge build up around rocker arms so changed brands. That oil was mostly likely not the same as it is today. Also I may have been running longer than I should have. 5000 mile oil changes is my target. However many times it goes well past that. (The shoe cobbler’s children go bare foot type of thing) I am now simi retired and getting much more prompt getting my own things done.
